D-Link Wireless AC1750 Simultaneous Dual-Band PoE Access Point
Quicklinx: 9H66WS00 Mfr#: DAP-2695
Type: Radio access point
Connectivity: Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac (draft), IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
Hurry, only 3 left in stock!
£164.99 ex VAT
£197.98 inc VAT
The DAP-2695 is a versatile, high power outdoor access point designed for harsh conditions, it is the ideal solution for creating hot spots or extending wireless networks outdoors.
  • Super-fast wireless AC performance
    The DAP-2695 delivers reliable, high-speed wireless performance using the latest 802.11ac standards with maximum wireless signal rates of up to 450 Mbps over the 2.4 GHz band, and 1300 Mbps over the 5 GHz band. This, coupled with support for the Wi-Fi Multimedia (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-2695 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP.
  • Versatile access point functionality
    The DAP-2695 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual-band wireless network. All six antennas on the DAP-2695 are detachable and can provide optimal wireless coverage over either the 2.4 GHz (802.11b, 802.11g, and 802.11n) or the 5 GHz (802.11a, 802.11n, and 802.11ac) band. Enclosed in a plenum-rated metal chassis, the DAP-2695 adheres to strict fire codes for placement in air passageways. For advanced installations, the DAP-2695 has integrated 802.3at Power over Ethernet (PoE) support, allowing this device to be installed in areas where power outlets are not readily available.
  • Security
    To help maintain a secure wireless network, the DAP-2695 supports both Personal and Enterprise versions of WPA and WPA2 (802.11i), with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts within the device itself. This access point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disablerogue AP detection, and wireless broadcast scheduling to further protect your wireless network. The DAP-2695 includes support for up to eight VLANs per band for implementing multiple SSIDs to further help segment users on the network.
  • Multiple operation modes
    To maximize total return on investment, the DAP-2695 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS/Bridge (No AP Broadcasting), and Wireless Client. With WDS support, network administrators can set up multiple DAP-2695s throughout a facility and configure them to bridge with one another while also providing network access to individual clients. The DAP-2695 also features advanced features such as load balancing and redundancy, for fail-safe wireless connectivity.
  • Network management
    Network administrators have multiple options for managing the DAP-2695, including web (HTTP), Secure Socket Layer (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and Telnet. For advanced network management, administrators can use the D-Link AP Manager II, or D-View SNMP management module to configure and manage multiple access points from a single location.
D-Link AirPremier DAP-2695 - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
19 cm x 19.88 cm x 3.65 cm
1.14 kg
Radio access point
Ruggedized Design
Indoor
19 cm
19.88 cm
3.65 cm
1.14 kg
External
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN
MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Quality of Service (QoS), RADIUS support, Network Access Protection (NAP), rugged
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac (draft)
Aerial
Antenna
External detachable
Antenna Qty
6
2 x 1000Base-T - RJ-45 , 1 x management - RJ-45
UL, IC, FCC
PoE+
10 - 90% (non-condensing)
9H66 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.21
9H66 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.80
9H66 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.20
Speed: 1750Mbps
Protocol: IEEE 802.11ac (draft)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 150 - 300
