D-Link Wireless AC1300 Wave2 Dual-Band PoE AP
Quicklinx: D0WDWS00 Mfr#: DAP-2610
Type: Radio access point
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11ac (draft) + 1 more
Compatibility: PC
  • IEEE 802.11n
£89.84 ex VAT
£107.80 inc VAT
The DAP-2610 wireless access point is designed to support small-to-medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the advanced speed of Wireless AC.
D-Link DAP-2610 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE
17 cm x 17 cm x 2.8 cm
314 g
Radio access point
17 cm
17 cm
2.8 cm
314 g
External
Wireless
Data Transfer Rate
1.3 Gbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
RADIUS support, Network Access Protection (NAP), dual band
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft)
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
3 dBi
1 x 1000Base-T (PoE) - RJ-45
Mounting brackets
UL, IC, FCC
PoE
10 - 90% (non-condensing)
Speed: 1.3Gbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac (draft)
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
