D-Link Wireless AC1200 Simultaneous Dual-Band with PoE Access Point
Free Wireless AP Controller software
Quicklinx: 9H65WS00 Mfr#: DAP-2660
Type: Radio access point
Connectivity: Wireless
Speed: 1200Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac (draft), IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
28 in stock
£88.63 ex VAT
£106.35 inc VAT
The DAP-2660 utilizes the cutting-edge speed of Wireless AC technology to give businesses the Next Generation Wireless Network. Combining Dual-Band Wireless AC1200 with an aesthetical design, the DAP-2660 can be deployed in any environment giving great wireless coverage without drawing attention to itself.
  • Enjoy high-performance wireless connectivity
    Harness the power of Wireless AC, enjoying wireless speeds of up to 1200 Mbps, perfect for demanding business applications.
  • Strong security and authentication features
    Maintain a highly secure network with a range of features including WPA/WPA2, Wireless LAN segmentation, and VLAN support.
  • Flexible operation
    Configure to use as an Access Point, a Wireless Distribution System (WDS) with Access Point, a WDS/bridge, or a wireless client.
D-Link DAP-2660 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
17 cm x 17 cm x 2.8 cm
316 g
Radio access point
17 cm
17 cm
2.8 cm
316 g
External
Wireless
Data Transfer Rate
1200 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
MAC address filtering, Wireless Distribution System (WDS) support, Quality of Service (QoS), RADIUS support, Network Access Protection (NAP), wireless bridge mode, Wireless Client Mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac (draft)
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T (PoE) - RJ-45
UL, IC, FCC
PoE
10 - 90% (non-condensing)
Speed: 1200Mbps
Protocol: IEEE 802.11ac (draft)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 50 - 100
