D-Link Wireless AC DualBand Unfied Access Point
Quicklinx: D0WNWS00 Mfr#: DWL-8710AP
  • IEEE 802.11n
The DWL-8710AP is equipped with two radio transceivers. The first is a 2.4 GHz 2 x 2 IEEE 802.11n interface that supports up to 300 Mbps of network throughput while the second one is a 5 GHz 2 x 2 802.11ac interface, capable of up to 867 Mbps of network throughput. The DWL-8710AP also features two Gigabit Ethernet network interfaces, designed to allow the administrator to easily bridge other networking devices into the network, such as a camera or another Wi-Fi access point.
The DWL-8710AP is IP67-compliant and is designed to operate in harsh outdoor environments and temperatures ranging from -30 up to 60 °C. In addition, all network interfaces are protected against electrical surges, enabling the device to be placed in areas where there is a risk of being struck by lightning.
When deployed in conjunction with D-Link's line of Unified Wireless Switches, up to 1024 DWL-8710APs may be centrally managed and provisioned, enabling the administrator to scale the Wi-Fi network to cover larger areas.
  • High performance
  • Robust design
  • Unified management
  • Security
    The DWL-8710AP supports all the latest in Wi-Fi security, including WPA, WPA2, and 802.1x. In addition, the DWL-8710AP supports up to 32 Virtual Access Points (VAP), which gives the administrator the flexibility to easily assign access privileges to different classes of users. When used together with D-Link's line of Unified Wireless Switches, security can be taken to a new level. Rogue APs in the network may be easily detected, and the administrator will be immediately notified of any security threat.
  • Automatic Radio Frequency (RF) management
    When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. When a DWL-8710AP senses a neighbor AP nearby, RF management will make it so that the DWL-8710AP will automatically select a non-interfering channel. This greatly reduces RF interference and makes it possible to deploy APs more densely. To further minimize interference, the DWL-8710AP will automatically lower it's transmit power when an adjacent AP is operating on the same channel. If a nearby AP is no longer present, the DWL-8710AP will dynamically increase it's transmit power again to increase wireless coverage.
  • Quality of service
    The DWL-8710AP supports Wi-Fi Multimedia (WMM), which prioritizes time sensitive traffic ahead of the pack in the event of a network data congestion. Furthermore, when a number of DWL-8710APs are in close proximity with each other, an access point will refuse new association requests once its resources are fully utilized. Instead, the association request will be picked up by a neighboring unit. This feature ensures that a single access point is never overloaded while others sit idle. Furthermore, the administrator has the option to limit the bandwidth on a per-user-basis, avoiding scenarios where a particular client might use up all the available bandwidth, affecting the performance of other users on the network.
D-Link DWL-8710AP - radio access point - Wi-Fi 5
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
22 cm x 4.5 cm x 25 cm
2.053 kg
Radio access point
Ruggedized Design
Outdoor
22 cm
4.5 cm
25 cm
2.053 kg
External
Wireless
Data Transfer Rate
1200 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, WLAN, LAN
Load balancing, VLAN support, Wireless Distribution System (WDS) support, Spanning Tree Protocol (STP) support, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, 2T2R MIMO technology, SNMP support
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP
IEEE 802.3u, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
4
Directivity
Omni-directional
2 x 1000Base-T (PoE) - RJ-45
UL, VCCI, C-Tick, cUL, CB, CCC, FCC, TELEC, IP67, NCC, EN 300 328, EN 301 893
PoE
16.5 Watt
-40 °C
70 °C
10 - 90% (non-condensing)
