Product
D-Link Wireless 4G router - WWAN - 4 port switch - 802.11b/g/n/ac
Quicklinx: D0W8WS00 Mfr#: DWR-953
  • IEEE 802.11n
More than 50 in stock
£95.14 ex VAT
£114.16 inc VAT
D-Link's DWR-953 Wireless AC750 4G LTE Router allows you to access and share your super-fast 4G LTE mobile broadband with multiple devices. Once connected, you can transfer data, stream media, and send SMS messages. Simply insert your SIM card and share your 4G LTE Internet connection through a secure wireless network or by using any of the four Fast Ethernet LAN ports. Simultaneous 4G LTE/3G mobile Internet and fixed broadband Internet support allows you to combine Internet connections to give you faster Internet speeds. You can also set up fail-safe Internet should either connections fail.
D-Link DWR-953 - wireless router - WWAN - 802.11a/b/g/n/ac - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS), reset button
IEEE 802.3u, IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
17 cm x 18 cm x 8 cm
400 g
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Wi-Fi AC Rating
AC1200
Status Indicators
Power, signal strength, WAN, LAN, 3G, SMS, Internet, 4G, 2.4/5 GHz, 2G
Communications
Wireless cellular modem
Cellular Protocol
Max Transfer Rate
150 Mbps
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
17 cm
18 cm
8 cm
400 g
10 - 90% (non-condensing)
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 733Mbps
Brand: D-Link
Price Range Ex VAT: 50 - 100
