D-Link Web Smart DGS-1210-48 48 Port Switch - 10/100/1000 + 4 x shared SFP
Quicklinx: 6ZYQWS00 Mfr#: DGS-1210-48
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: Yes
POE: [N/A]
£196.59 ex VAT
£235.90 inc VAT
The DGS-1210 Series Gigabit Smart Managed Switches with Fibre Uplinks is the latest generation of D-Link Smart Managed Switches featuring high port density and optional PoE support. With D-Link Green 3.0 technology, the series offers a high level of energy saving and efficiency, as well as compliance with IEEE 802.3az Energy Efficient Ethernet standard.
  • Seamless integration
    The DGS-1210-48 includes 48 10/100/1000 Mbps ports capable of connecting to existing Cat. 5 twisted-pair cables. Additionally, the last four ports of the DGS-1210-48 combine SFP and copper connectivity into one port and therefore provide a flexible solution for server connections via fiber interface. Using the default presets, the administrator can quickly set up the switch without worrying about reconfiguring any settings and providing easy access for the user.
  • Extensive layer 2 features
    Equipped with a complete lineup of L2 features, these switches include IGMP snooping, port mirroring, spanning tree and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfer. At 2000 Mbps full duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss.
  • QoS & bandwidth control
    The switch is perfect for deployment in a VoIP environment, as it supports Auto Voice VLAN and Differentiated Services Code Point (DSCP) QoS for VoIP application. Auto Voice VLAN will automatically place voice traffic from an IP phone to an assigned VLAN and by doing so enhance the VoIP service. With a higher priority and individual VLAN, this feature guarantees the quality and security of VoIP traffic. DSCP marks parts of an IP packet, enabling different levels of service to be assigned for network traffic. With bandwidth control, the network administrator can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
  • Secure your network
    D-Link's unique Safeguard Engine function protects the switch against traffic flooding caused by virus attacks. The switch also supports 802.1X port-based authentication, allowing the network to be authenticated through an external RADIUS server. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210-48 includes ARP spoofing prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames on a LAN, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages to the network. To prevent ARP spoofing attacks, the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP Server Screening feature screens rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
  • Versatile management
    The DGS-1210-48 provides a SmartConsole utility and a web-based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole easily allows customers to discover multiple D-Link web smart switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC and it also provides an easy initial setting of the smart switches. Switches within the same L2 network segment that are connected to the user's PC are displayed on screen for instant access.
  • D-Link Green
    The DGS-1210-48 implements D-Link Green, an innovative concept that provides energy savings without sacrificing operational performance or functionality. The switch reacts when devices attached to it are turned off, by placing the corresponding port in a standby mode that requires less power. It also automatically detects the length of connected cables, which allows it to cut power usage on shorter cable connections up to 20 m.
D-Link Web Smart DGS-1210-48 - switch - 48 ports - Managed
Switch - 48 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x shared SFP
MAC Address Table Size
16K entries
Jumbo Frame Support
13000 bytes
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, TFTP
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, Safeguard Engine, D-Link Green Technology
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3az
44 cm x 20.7 cm x 4.4 cm
2.3 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
16K entries
Jumbo Frame Support
13000 bytes
Authentication Method
RADIUS
RAM
1 MB
Built-in Devices
Led panel
Status Indicators
Port transmission speed, power, link OK, link/activity
48 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
33.4 Watt
MTBF
322,402 hours
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC Class A
44 cm
20.7 cm
4.4 cm
2.3 kg
50 °C
10 - 95%
Ports: 48
Managed: Yes
POE: [N/A]
Brand: D-Link
Stock Status: Clearance
Price Range Ex VAT: 150 - 300
