The Vigilance Wireless HD Camera is a professional, full featured HD camera that is easy to install and highly affordable. Capable of viewing up to 10 metres at night thanks to its infrared LED illuminator, this camera can monitor an area even in complete darkness.
A built-in microphone and speaker allows for 2-way communication, which is ideal for use in entryways or for caretaker applications. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send a notification when motion is detected.
Vigilance range
The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments.
Security Installer Focused
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
- D-Link DCS-4201 - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Built-in speaker, two-way audio capability, built-in microphone
- 5.8 cm x 3.07 cm x 9.5 cm
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 1 lux - colour - F2.4 , 0.5 lux - B&W - F2.4 , 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 1.8 mm
- Lens Iris
- F/2.4
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- IR filter, e-mail alerts, ONVIF support, 3D Noise Reduction Technology, Motion Detection Technology, Event Notification
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 5.8 cm
- 3.07 cm
- 9.5 cm
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 10 m
- Digital Video Capture Resolution
- 1280 x 720, 960 x 720
- Frame Rate (max)
Image Sensor
- CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 1.8 mm
- Lens Iris
- F/2.4
- Horizontal Field of View (degree)
- 97.6
- Vertical Field of View (degree)
- 69.2
- Network Interface
- Network Protocols
- IPv6
- Supported Memory Cards
- microSD Card, microSDHC Card
- C-Tick, FCC, LVD
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
