The Vigilance Full HD Outdoor PoE Mini Dome Camera is a professional, full featured full HD Camera with IP-66 (weather-proof) housing, specifically designed to withstand adverse weather conditions. Incorporating IR LED illuminator, WDR and 3DNR support, you get up to 30 meters night vision and clear detailed images in contrasting and low light environments.
Vigilance range
The Vigilance Range offers professional, full featured high definition video surveillance that is easy to install and highly affordable. The range consists of cameras designed specifically to meet different surveillance and environmental requirements. From standalone surveillance solutions that allow you to record video without additional software or equipment, to weather/vandal-proof cameras for harsh environments. -
Security installer focused
Specifically designed for any security installer looking to offer digital video surveillance, this versatile range of cameras is designed for easy selection and simple installation. You'll be able to guide your customers to the right choice for their needs and they will be delighted with the quality, reliability and straightforward ease-of-use that Vigilance delivers.
- D-Link Vigilance DCS-4802E Full HD Outdoor PoE Mini Dome Camera - network surveillance camera
- Network surveillance camera - pan / tilt - outdoor - vandal-proof
- 11.3 cm x 11.3 cm x 7.77 cm
- 635 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3" - 2 MP
- Minimum Illumination
- 1 lux - colour - F2.0 , 0.5 lux - B&W - F2.0 , 0 lux - IR
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Panning Range (degree)
- 350
- Tilting Range (degree)
- 60
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V
- Motion sensor, Power over Ethernet, e-mail alerts, Wide Dynamic Range (WDR), 3D Noise Reduction Technology, Open Network Video Interface Forum (ONVIF), NAS-Ready
- Environmental Parameters (operating)
- -30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Wired
- 11.3 cm
- 11.3 cm
- 7.77 cm
- 635 g
Camera
- Colour - Day&Night - pan / tilt - outdoor - vandal-proof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Modes
- 1080p
- Digital Zoom
- 10
- Infrared LEDs
- Video Capture
- 1920 x 1080 @ 30 fps
Image Sensor
- 2 MP CMOS 1/3"
Lens Construction
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Horizontal Field of View (degree)
- 96
- Vertical Field of View (degree)
- 54
Panning
- Range (degree)
- 350
Tilting
- Range (degree)
- 60
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE, IGMP, Samba, QOS, 3GPP/ISMA, CoS
- FCC Class A certified, C-Tick, IK10, LVD
- Power Requirements
- DC 12 V
- Power Device
- No power supply
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.93 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.49 |
