DCS-4622 is a Full HD 360° network camera as an entry type for video surveillance and security. This camera adopts 3MP progressive scan CMOS sensor. The camera is designed for both indoor and day/night applications, thus, the camera built-in removable IR-cut filter and IR LED, which can support long distance. The DCS-4622 has a built-in 802.3af compliant PoE module, that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling.
- D-Link DCS 4622 - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- Audio
- Yes: built-in speaker, built-in microphone
- 9.7 cm x 9.7 cm x 4.83 cm
- 210 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1536
- Frame Rate (max)
- 25 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3" - 3 MP
- Minimum Illumination
- 0.5 lux - colour , 0.25 lux - B&W , 0 lux - IR
- Focal Length
- 1.1 mm
- Focus Adjustment
- (min distance 30 cm)
- Lens Iris
- F/2.0
- Tilting Range (degree)
- 15
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Sharpness control, saturation control, brightness control, contrast control, Wide Dynamic Range (WDR), built-in IR illuminator, exposure control, ICR filter, sound detection
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Audio Formats
- AAC, G.711
- Form Factor
- Dome
- Wired
- 9.7 cm
- 9.7 cm
- 4.83 cm
- 210 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1536
- Motion Detection
- Digital Zoom
- 10
- Exposure Range
- 1/8 sec - 1/10000 sec
- Infrared LEDs
- Infrared Distance
- 8 m
- Video Capture
- 1920 x 1536 @ 25 fps
- Supported Image Formats
- JPEG
Image Sensor
- 3 MP CMOS 1/3"
Lens Construction
- Focal Length
- 1.1 mm
- Lens Iris
- F/2.0
- Min Focus Distance
- 30 cm
- Horizontal Field of View (degree)
- 180
- Vertical Field of View (degree)
- 180
Tilting
- Range (degree)
- 15
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, QOS, CoS, DSCP
- Ports
- LAN/power - RJ-45
- Supported Memory Cards
- microSD Card, microSDXC Card
- Included Accessories
- Mounting kit
- C-Tick, FCC, IEEE 802.3af
- Power Requirements
- DC 12 V / PoE
- Power Device
- 4.6 Watt
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 10
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
