Your basket is empty
D-Link USB 3.0 to Gigabit Ethernet Adapter
Quicklinx: 9H5BWS00 Mfr#: DUB-1312
The DUB-1312 USB 3.0 Gigabit Ethernet Adapter allows you to instantly add gigabit connectivity to your desktop, notebook, or netbook computer. Combining SuperSpeed USB 3.0 with Gigabit Ethernet connectivity, you can transfers large files in no time, stream high definition movies without buffering, or make light work of backups to a server or network storage device.
D-Link DUB-1312 - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
7.44 cm x 2.1 cm x 1.6 cm
46.4 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0, USB 3.0
Linux 2.6.14, Microsoft Windows XP SP3, Apple MacOS X 10.6 - 10.8, Microsoft Windows Vista / 7 / 8
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, link/activity
USB powered
1 x 1000Base-T - RJ-45
FCC
7.44 cm
2.1 cm
1.6 cm
46.4 g
10 - 90% (non-condensing)
