The D-Link DUB-C5AB is a 15-feet Hi-Speed USB 2.0 certified type "A" to type "B" cable. The D-Link DUB-C5AB connects USB 2.0 or USB 1.1 devices to your computer or USB hub. The D-Link DUB-C5AB provides users with a high-quality, hi-speed USB 2.0 cable that reaches 15 feet, long enough cable to take care of all your USB cable needs.
- D-Link USB cable - 4.57 m
- USB cable
- Length
- 4.57 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- USB cable
- American Wire Gauge (AWG)
- 20
- Length
- 4.57 m
- Connector
- USB / USB 2.0, FCC Class B certified, USB-IF
