D-Link Unified Wireless N Simultaneous Dual band PoE Access Point
Quicklinx: D0WKWS00 Mfr#: DWL-6600AP/PC
  • IEEE 802.11n
The DWL-6600AP is designed to be the best-in-class indoor Access Point for business environments. With high data transmission speeds, load balancing features, it can be deployed as a standalone wireless Access Point or used as the foundation for a managed wireless network.
  • Performance without compromise
    Using the wireless N technology, the DWL-6600AP delivers great wireless performance and coverage in a compact design.
  • Broadcast on 32 SSIDs simultaneously
    Supports up to 32 SSIDs, 16 per radio, including Station Isolation.
  • Smart design
    The DWL-6600AP has a discrete design, similar in look to a smoke detector, so that it can be mounted easily onto any wall or ceiling without looking out of place in an office or home.
  • Managed using D-Link's wireless controller or unified wireless switch
    All D-Link's unified wireless access points can be managed using D-Link's wireless controller or unified switch.
  • Simultaneous dual-band wireless
    Supports up to 300Mbps for the 5Ghz band and up to 300Mbps for the 2.4Ghz band.
  • Fast seamless roaming
    Combining the DWL-6600AP with a unified wireless switch or controller allows you to create a wireless network that enables people to move freely around a building without losing connectivity.
  • Secure and green design
    The DWL-6600AP has a wireless scheduler feature, which turns off wireless functionality when it isn't needed, saving power and increasing network security.
  • Versatility built as standard
    Whether you intend to use a single access point or roll out a large corporate network, the DWL-6600AP coupled with a D-Link wireless controller or Switch makes managing your wireless network simple.
D-Link Unified N Simultaneous Dual-Band PoE Access Point - radio access point - Wi-Fi
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 32
Power Over Ethernet (PoE) Supported
PoE
15.6 cm x 15.6 cm x 7.75 cm
500 g
Radio access point
Ruggedized Design
Indoor
15.6 cm
15.6 cm
7.75 cm
500 g
External
Wireless
Data Transfer Rate
600 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Max Range Indoors
100 m
MAC address filtering, Wireless Distribution System (WDS) support, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, 2T2R MIMO technology, rogue access point detection, 802.1x authentication
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
Secure Shell (SSH)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
External detachable
1 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 4 x aerial
FCC Class B certified, VCCI, C-Tick, cUL, IC, UL 2043, EN 60950-1, EN 60601-1-2, TELEC, LVD, NCC
PoE
10 - 90% (non-condensing)
