D-Link Unified AC1200 Simultaneous  Dual-Band PoE Access Point
Quicklinx: D0WLWS00 Mfr#: DWL-6610AP
Type: Radio access point
Connectivity: Wireless
Speed: 1167Mbps
Protocol: IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£126.26 ex VAT
£151.51 inc VAT
The DWL-6610AP is an affordable, Unified Wireless AC1200 Access Point, enabling businesses of all sizes create the fastest wireless network possible. With a sleek and stylish design, the DWL-6610AP can be discreetly deployed anywhere.
  • Greater reach and flexibility
    The DWL-6610AP provides excellent connectivity by using a 2 x 2 antenna implementation, allowing high combined data rates over the air. Beamforming technology enables the DWL-6610AP to have more flexibility in any deployment scenario. It provides the high performance over two bands, so wireless clients can stream media faster and farther than before using existing devices.
  • Centrally manage your wireless network
    The DWL-6610AP can be centrally managed, which allows for a large number of APs to be deployed and managed easily and efficiently. Once the APs are discovered by the switch / controller, the administrator can push specific configuration sets onto them rather than having to do so individually. In addition, RF resource management and security are also managed centrally, allowing the administrator to preemptively identify potential deficiencies and weaknesses in the network.
  • Self-configuring cluster
    For small businesses that need to deploy multiple APs but lack the resources to tackle the complicated task of network management, the DWL-6610AP's self-configuring cluster feature offers the ideal solution. When a small number of DWL-6610APs are deployed on the network, they may be configured to form a self-configuring cluster. Once the administrator configures one access point, the same configuration can then be applied to all remaining APs. Up to 8 APs may be used to form a cluster, making setting up your business wireless network a breeze.
  • Superior performance
    The DWL-6610AP features a powerful CPU, giving it a performance boost. The high-gain internal omnidirectional antenna increases its reach, eliminating dead spots and filling hard-to-reach places. Bandsteering technology enables the AP to balance the load between its two radios rather than forcing all users onto the 2.4 GHz band, allowing for smooth streaming of video, instant transmission of SMS and e-mail, and fast downloads for mobile devices.
  • Automatic RF management saves power and money
    When a number of access points are deployed close to each other, interference may result if proper RF management isn't implemented. When a DWL-6610AP senses a neighbor nearby, it will automatically select a non-interfering channel. This greatly reduces RF interference and will allow the administrator to deploy APs more densely. To further minimize interference, when a nearby AP is operating on the same channel, the DWL-6610AP will automatically lower its transmission power. When, for whatever reason, the nearby AP is no longer present, the DWL-6610AP will increase its transmission power to expand coverage.
  • Quality of Service for increased connectivity
    The DWL-6610AP supports Quality of Service (QoS) for enhanced throughput and better performance of time-sensitive traffic like VoIP and streaming DSCP. In the event of network congestion, time-sensitive traffic can be given priority ahead of other traffic. Furthermore, when a number of DWL-6610AP units are in close proximity to each other, an access point will refuse new association requests once its resources are fully utilized, allowing the association request to be picked up by a neighboring unit. This feature ensures that no single AP is overburdened while others nearby sit idle.
D-Link DWL-6610AP - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
AC 120/230 V
15.879 cm x 15.879 cm x 6.939 cm
500 g
Radio access point
15.879 cm
15.879 cm
6.939 cm
500 g
External
Wireless
Data Transfer Rate
1167 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN
Power over Ethernet (PoE), VLAN support, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, ceiling mountable
Encryption Algorithm
AES, TKIP, WPA, WPA-Enterprise
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x console - RJ-45
C-Tick, BSMI, cUL, IC, UL 2043, FCC, LVD, NCC, EN 300 328 V1.8.1:2012, ETSI EN 301 893 V1.7.1
External power adapter
AC 120/230 V
10 - 90% (non-condensing)
Speed: 1167Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 100 - 150
