Product
Brand
D-Link SFP 100Base-FX Multi-mode Fibre Transceiver
Quicklinx: 9H8WWS00 Mfr#: DEM-211
The D-Link's DEM-211 SFP transceiver provides a high performance solution for serial optical data communication applications. It is hot swappable, Small Form Factor Pluggable (SFP) compliant with the Multi-Source Agreement (MSA) specification. The transceiver has duplex LC connectors and provides IEEE 802.3u compliant link for up to 100Mbps in the half duplex mode (or 200Mbps full-duplex mode) transmission for fiber cable applications.
D-Link's highly integrated transceiver offers low jitter performance for extended optical links support without performance degradation. This high performance enables reliable data transfer in short-, intermediate- and long-distances for building, factory, campus and metropolitan networking applications.
D-Link DEM 211 - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
DES 1210; DGS 3100-24, 3100-24P, 3100-48, 3100-48P; xStack DES-3552
Plug-in module
Wired
Cabling Type
100Base-FX
100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Full duplex mode
IEEE 802.3u, IEEE 802.3z, IEEE 802.3x
1 x Ethernet 100Base-FX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
FCC Class B certified, UL, TUV, VCCI, ICES-003, RoHS
70 °C
10 - 90%
D-Link DES 1210 , D-Link DGS 3100-24, 3100-24P, 3100-48, 3100-48P , D-Link xStack DES-3552
