mydlink™ Cloud Services: the easiest way to monitor your home
Connecting a camera to your network and accessing it has traditionally required complex configuration. mydlink™ Cloud Services make it easy to access your camera from wherever you are, whenever it's convenient for you. A step-by-step guide has your camera up and running in a matter of minutes. Then via a simple website you can set up a mydlink™ account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink™ account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the mydlink™ app for your iPhone®, iPad® or Android™ and you can quickly and easily view your camera feed from anywhere with a wireless or 3G connection.
Thanks to this app, you can monitor on-the-go even if you don't have access to a computer.
Cover and protect wider areas
This sophisticated home camera provides you with the ideal 24-hour monitoring solution, allowing you to see up to 340 degrees of any room it is placed in thanks to its Pan/Tilt feature. Control its Pan/Tilt feature via the mydlink™ portal, the included remote control, or the mydlink™ app. This camera can also be set to automatically move to specific preset positions, allowing the camera monitor a wider area.
Night vision
The Pan/Tilt/Zoom Cloud Camera comes with built-in infrared LEDs that allow for monitoring even in complete darkness. The 5-metre illumination distance makes it suitable for monitoring whatever is important to you: whether it is your baby in the nursery or your office by night.
A complete monitoring system
This cloud-enabled camera includes a microSD card slot to record audio and video directly onto the camera, without the need of a computer being switched on. You can setup the camera to record only when motion is detected, or continuously, via the camera's intuitive web interface. Once the microSD* card is at capacity, older footage will be recorded over. You can watch and examine recorded video directly from the mydlink™ portal later on from anywhere, at any time.
The built-in PIR sensor can detect motion and trigger email alerts. An additional sensor attached to a door or window can be connected to its standard I/O port. All these features can be easily configured via the User Interface, which makes this camera a truly comprehensive home monitoring system.
*microSD card not included.
- Header / Manufacturer
- D-Link
- Header / Product Line
- D-Link DCS
- Video Input / Camera Type
- Network CCTV camera
- Header / Model
- 5222L
- Video Input / Max Digital Video Resolution
- 1280 x 720
- Video Input / Camera Mechanical Design
- Pan / tilt
- CCTV / Panning Range (degree)
- 340
- CCTV / Tilting Range (degree)
- 120
- CCTV Camera Sensitivity / Minimum Illumination (lux)
- 0
- Environmental Parameters / Min Operating Temperature
- 0 °C
- Header / Compatibility
- Android, Apple iOS, Mac, PC
- Header / Packaged Quantity
- 1
- CCTV / Compatible Sensor Size
- 1/4"
- Optical Sensor / Sensor Size
- 1/4"
- Dimensions & Weight / Depth
- 10.32 cm
- Dimensions & Weight / Width
- 12 cm
- Dimensions & Weight / Height
- 13 cm
- Video Input / Frame Rate
- 30 frames per second
- Dimensions & Weight / Weight
- 340 g
- Environmental Parameters / Max Operating Temperature
- 40 °C
- Optical Sensor / Sensor Size (metric)
- 6.4 mm ( 1/4" )
- CCTV / Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, ICMP, IGMP, NTP, PPPoE, RTCP, RTP, RTSP, SMTP, TCP/IP, UDP/IP
- Networking / Network Interface
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Networking / Network Interfaces
- Fast Ethernet
- Lens System / Focal Length Control
- Fixed focal
- Video Input / Digital Video Format
- H.264, MJPEG
- General / Compression Format
- H264, MJPEG
- Networking / Remote Management Protocol
- HTTP, HTTPS
- Video Input / Image Recording Format
- JPEG
- Flash Memory / Supported Memory Cards
- microSD Card
- System Requirements / OS Required
- Microsoft Windows Vista / 7 / 8, Microsoft Windows XP SP3
- Miscellaneous / Product Colour
- White
- Video Input / Audio Support
- Video Input / Day & Night Functionality
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
