D-Link Securicam FIXED Megapixel Day & Night WDR Network Camera
Quicklinx: 9TSZWS00 Mfr#: DCS-3710/B
D-Link's Megapixel Day & Night WDR Network Camera is an IP camera equipped with a 1/3" Megapixel WDR Progressive Scan CMOS and a 2.8~12mm DC auto iris lens. The DCS-3710 captures video in both dark and light environments, or even subjects shot against a backlight by neutralising and generating a realistic image.
The camera is ideal for 24-hour surveillance, with its Infrared-Cut Removable (ICR) filter for night vision. 802.3af compliant Power over Ethernet (PoE) makes for easy installation by providing both data and power connection through a single cable. The cameras provide DI/DO interfaces for connection to external devices such as IR sensors, switches, and alarm relays for effective surveillance. It also includes a RS-485 interface, providing connectivity to an optional pan/tilt enclosure, and microphone and speaker ports for 2-way communication. Additionally, a 12V interface provides power for an optional LED illuminator.
The DCS-3710 provides high quality real-time videos in MPEG-4 or MJPEG compression. Up to three different profiles may be configured to operate simultaneously. Footage can be stored on an SD card in the camera itself or on a NAS device or Network Video Recorder (NVR). D-Link's D-ViewCam software is included to manage up to 32 cameras in real time, send automated e-mail alerts, and record video to your hard drive when motion is detected or according to a set schedule.
Exceptional resolution at all times, low power consumption and a wide array of functionalities make this camera a competitive solution for high-end professional IP surveillance applications requiring uncompromising security.
  • High resolution surveillance
    The D-Link DCS-3710 is a high-end Megapixel Day & Night WDR Network Camera, equipped with a 1/3" megapixel WDR progressive scan CMOS and a 2.8-12mm DC auto iris lens. The DCS-3710 captures video in both dark and light environments, and even subjects shot against a backlight by neutralizing and generating a realistic image. In addition, the removable IR-cut filter for day/night functionality provides clear details and high quality video at any hour of the day. The DCS-3710 incorporates Power over Ethernet (PoE) and an SD card slot. Consequently, it can be easily installed in a variety of locations.
  • Multiple VIDEO streams
    The DCS-3710 supports simultaneous streaming of MPEG-4 and MJPEG video to provide both high-quality, and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which required high image detail. MPEG-4 produces a small file size, making it more useful for extended recording or for use in low bandwidth networks. Additionally, the DCS-3710 supports multicast MPEG-4 streaming allowing users to view contact by subscribing to a multicast IP address on the network.
  • Flexible connectivity
    The DCS-3710 includes input and output ports allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with a RS-485 interface, providing connectivity to an optional pan/tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3710. Additionally, a 12V interface provides power for an optional LED illuminator.
  • Wide Dynamic Range (WDR) applications
    The Wide Dynamic Range (WDR) function of a camera provides clear images even under backlit conditions where the intensity of illumination can vary significantly. The DCS-3710 is recommended for extreme high-contrast environments. For example, when placed indoors, the DCS-3710 will adjust itself to the intense sunlight that may be streaming in through a nearby window. This makes it an ideal solution for security applications.
D-Link DCS-3710 Megapixel Day & Night WDR Network Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: two-way audio capability
8 cm x 14 cm x 5.3 cm
Wired
Camera
Colour - Day&Night
Optical Zoom
4.3 x
Max Resolution
1280 x 960
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.3 lux - colour , 0.02 lux - B&W
Focal Length Control
Vari-focal
Focal Length
2.8 mm - 12 mm
Lens Iris
F/1.3 - auto iris (DC)
Ethernet 10Base-T/100Base-TX
Control Interface
RS-485
Voltage
AC 120/230 V DC 12 V
Motion sensor, IR filter, auto exposure control, progressive scanning, SD-card slot, Power over Ethernet, e-mail alerts, image flip, image mirror, Wide Dynamic Range (WDR), auto gain control, auto white balance
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% relative humidity
Audio Support
Wired
8 cm
14 cm
5.3 cm
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, 3GPP
Max Digital Video Resolution
1280 x 960
Video Capture
1280 x 960 @ 30 fps , 1280 x 720 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps , 160 x 120 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/3"
Lens Construction
Vari-focal
Optical Zoom
4.3 x
Focal Length
2.8 mm - 12 mm
Lens Iris
F/1.3 auto iris (DC)
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, RTCP, PPPoE, SMB
Control Interface
RS-485
Alarm Inputs Qty
2
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX , 1 x microphone - input , 1 x speakers - output
FCC Class A certified, C-Tick Class A
Power Requirements
AC 120/230 V - DC 12 V - 1.25 A
Software Included
Drivers & Utilities
Microsoft Windows Vista / XP
Relative Humidity (operating)
20 - 80%
