D-Link's DCS-6815 is a high-performance high speed dome Network camera, ideal for business surveillance application. Speed Dome cameras are very popular in CCTV system. DCS-6815 targets professional level market. Use high performance SoC (System-on-Chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-6815 supports dual-codec for live monitoring and recording. With the free-bundled 32 channel recording software, the DCS-6815 is an ideal and professional solution for high quality viewing and reliable recording.
The DCS-6815 is a compact lightweight design high speed dome network camera that includes a weather proof housing which meets IP66 international standard and can withstand the toughest environment. Additional, with built-in heater and fan, the DCS-6815 is capable of operating at temperatures ranging from -45°C to 50°C making it the best choice for extreme weathers.
Powerful surveillance
D-Link's DCS-6815 is a high-performance high speed dome Network camera, ideal for business surveillance application. Speed Dome cameras are very popular in CCTV system. DCS-6815 targets professional level market. Use high performance SoC (System-on-Chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-6815 supports dual-codec for live monitoring and recording. -
Outdoor integrated high speed dome camera
The DCS-6815 is a compact lightweight design high speed dome network camera that includes a weather proof housing which meets IP66 international standard and can withstand the toughest environment. Additional, with built-in heater and fan, the DCS-6815 is capable of operating at temperatures ranging from -45°C to 50°C making it the best choice for extreme weathers. -
Proportional pan and tilt speed
The pan and tilt speed is proportional to the optical zoom ratio of the camera; when the camera is zoomed in, the panning speed will be slowed to improve camera tracking and controllability. This feature will prevent losing sight of the subject when the camera zoos in. -
Day/night function with removable IR cut filter
The IR cut filter can be automatically or manually removed depending on the light condition, enabling the camera to capture color video in light condition and back-and - white video in low light condition. -
Robust performance:
The DCS-6815 contains robust functions such as schedule and home function. The schedule and home function can be customized for various types of surveillance needs, enabling the camera to operate automatically and reducing use input for a more efficient surveillance solution.
- D-Link DCS-6815 High Speed Dome Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - weatherproof
- 17.2 cm x 17.2 cm x 30.3 cm
- 6 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night - NTSC, PAL
- Optical Zoom
- 18 x
- Optical Sensor Type
- EXview HAD CCD - 1/4"
- Focal Length
- 4.1 mm - 73.8 mm
- Lens Iris
- Auto iris
- Panning Range (degree)
- 360
- Tilting Range (degree)
- -10 to +90
- Ethernet 10Base-T/100Base-TX
- Motion sensor, Backlight Compensation (BLC), IR filter, e-mail alerts, image flip, Wide Dynamic Range (WDR), heater, built-in cooling fan, auto gain control, auto white balance
- Environmental Parameters (operating)
- -40 °C - 50 °C; 20 - 80% relative humidity
- Form Factor
- Dome
- Wired
- 17.2 cm
- 17.2 cm
- 30.3 cm
- 6 kg
Camera
- Colour - Day&Night - fixed - weatherproof
- Video Format
- NTSC, PAL
- Digital Video Format
- MPEG-4, MJPEG
- Digital Zoom
- 12
- Exposure Range
- 1/10000 sec - 1 sec
- Video Capture
- 176 x 120 @ 30 fps , 352 x 240 @ 30 fps , 720 x 480 @ 30 fps , 176 x 144 @ 25 fps , 352 x 288 @ 25 fps , 720 x 576 @ 25 fps
- Supported Image Formats
- JPEG
Image Sensor
- EXview HAD CCD 1/4"
Lens Construction
- Optical Zoom
- 18 x
- Focal Length
- 4.1 mm - 73.8 mm
- Lens Iris
- Auto iris
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 90
Tilting
- Range (degree)
- -10 to +90
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, PPPoE
- Alarm Inputs Qty
- 8
- Alarm Outputs Qty
- 1
- 1 x network - Ethernet 10Base-T/100Base-TX
- IEC 60529 IP66, FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Microsoft Windows Vista / 2000 / XP
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
