The IEEE 802.3at (PoE+)/802.3af (PoE) compliant DPE-301GI Gigabit PoE+ Injector is designed to supply data and up to 30 watts of power to PoE-enabled devices such as network cameras and wireless access points.
- D-Link DPE-301GI - PoE injector - 30 Watt
- PoE injector - external
- 70 g
- Output Voltage
- 54 V
- Power Capacity
- 30 Watt
- Output connectors
- 1 x RJ-45
- Included Accessories
- Power adapter
- 10.98 cm x 6.22 cm x 2.45 cm
- Power Output Connectors Details
- 1 x RJ-45
- Output Voltage
- 54 V
- Power Capacity
- 30 Watt
- Power adapter
- Cables Included
- Network cable - external
- UL, VCCI, BSMI, CB, CCC, IC, FCC, RoHS, RCM
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- 10.98 cm
- 6.22 cm
- 2.45 cm
- 70 g
