The D-Link DCS-6315 HD WDR Varifocal Outdoor Fixed Dome Network Camera is a high definition professional video surveillance and security solution suitable for small, medium and large enterprises. The camera uses a high-sensitivity megapixel progressive scan CMOS sensor with onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in video surveillance applications without the need for additional accessories.
Rugged construction
IP68 weatherproof housing and weather shield makes the DCS-6315 ideal for the most demanding of surveillance applications. -
HD resolution with wide dynamic range
A high-resolution megapixel sensor provides HD resolution while Wide Dynamic Range technology ensures that you capture the details you need. -
Color night vision
Keep an eye on your home or office around the clock with vibrant color images, even in low light environments.
- D-Link DCS-6315 - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- 12.8 cm x 12.8 cm x 11.37 cm
- 1.112 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 4.3 x
- Max Resolution
- 1280 x 720
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0 lux - IR - F1.4 , 0.1 lux - colour - F1.4 , 0.02 lux - B&W - F1.4
- Focal Length Control
- Vari-focal
- Focal Length
- 2.8 mm - 12 mm
- Lens Iris
- F/1.4
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Manual exposure, date/time stamp, sharpness control, saturation control, 16:9 widescreen mode, brightness control, Power over Ethernet, contrast control, Wide Dynamic Range (WDR), ONVIF support, built-in LED illuminator, Motion Detection Technology, infrared cut filter, Privacy Mask Function, microSD/SDHC/SDXC Memory Card slot
- Environmental Parameters (operating)
- -30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Wired
- 12.8 cm
- 12.8 cm
- 11.37 cm
- 1.112 kg
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Capture
- 1280 x 720 @ 30 fps , 800 x 450 @ 30 fps , 640 x 360 @ 30 fps , 480 x 270 @ 30 fps , 320 x 176 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 480 x 360 @ 30 fps , 320 x 240 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/3"
Lens Construction
- Vari-focal
- Optical Zoom
- 4.3 x
- Focal Length
- 2.8 mm - 12 mm
- Lens Iris
- F/1.4
- Horizontal Field of View (degree)
- 28 - 90
- Vertical Field of View (degree)
- 16 - 58.8
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, QOS, CoS
- Ports
- LAN/power - RJ-45 , Audio line in - 3.5 mm jack , Audio line out - 3.5 mm jack
- C-Tick, FCC, IK10, IP68
- Power Requirements
- DC 12 V / PoE
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 12.24 Watt
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
