The N300 Wi-Fi Range Extender is a wall-plug Wi-Fi range extender that lets you extend an existing Wi-Fi network simply by placing it anywhere in your home. Supporting Wireless N, this tiny yet powerful N300 Wi-Fi Range Extender gives you connection speeds of up to 300 Mbps, while still being backwards compatible with your existing wireless devices.
Extend your wireless network and more
Increase the coverage of your home Wi-Fi network with the sleek and easy-to-use N300 Wi-Fi Range Extender. N300 technology ensures fast connection speeds whilst providing backward compatibility with older wireless devices in your network, allowing you to enjoy a reliable wireless connection. Alternatively, use the built-in Ethernet port to create a personal Wi-Fi hotspot in hotel rooms with wired Internet access whether you are away on holiday or business. You can also add Wi-Fi connectivity to computers, smart TVs and games consoles with Ethernet ports. -
Easy to set up, easy to use
Setting up the N300 Wi-Fi Range Extender is simple. You can use the supported QRS Mobile app on your iOS and Android smartphones and tablets to set up easily without needing a computer. Alternatively, you can use one-touch setup by pushing the WPS push-button on the N300 Wi-Fi Range Extender and your Wi-Fi router, to instantly extend your Wi-Fi coverage. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device. -
Compact, convenient design
The N300 Wi-Fi Range Extender is a compact device that is ideal for use at home or in a small office. The visual signal indicator LED makes it easy to find suitable placement location. Its space-saving wall-plug design easily saves you the hassle of dealing with a power adapter and cable. The discreet and unobtrusive appearance blends easily into the decor of your home or office.
- D-Link DAP-1330 N300 Wi Fi Range Extender - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power
- AC 120/230 V (50/60 Hz)
- 5.55 cm x 3.4 cm x 7.7 cm
- 86.9 g
- 5.55 cm
- 3.4 cm
- 7.7 cm
- 86.9 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Status, signal strength, WPS
- Wi-Fi Protected Setup (WPS), Push Button Configuration (PBC)
- Encryption Algorithm
- WPA, WPA2
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- UL, C-Tick, CB, IC, FCC
- Power Device
- Internal power supply
- Voltage Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
