D-Link N300 Wireless Range Extender
Quicklinx: BKHTWS00 Mfr#: DAP-1330/B
  • IEEE 802.11n
The N300 Wi-Fi Range Extender is a wall-plug Wi-Fi range extender that lets you extend an existing Wi-Fi network simply by placing it anywhere in your home. Supporting Wireless N, this tiny yet powerful N300 Wi-Fi Range Extender gives you connection speeds of up to 300 Mbps, while still being backwards compatible with your existing wireless devices.
  • Extend your wireless network and more
    Increase the coverage of your home Wi-Fi network with the sleek and easy-to-use N300 Wi-Fi Range Extender. N300 technology ensures fast connection speeds whilst providing backward compatibility with older wireless devices in your network, allowing you to enjoy a reliable wireless connection. Alternatively, use the built-in Ethernet port to create a personal Wi-Fi hotspot in hotel rooms with wired Internet access whether you are away on holiday or business. You can also add Wi-Fi connectivity to computers, smart TVs and games consoles with Ethernet ports.
  • Easy to set up, easy to use
    Setting up the N300 Wi-Fi Range Extender is simple. You can use the supported QRS Mobile app on your iOS and Android smartphones and tablets to set up easily without needing a computer. Alternatively, you can use one-touch setup by pushing the WPS push-button on the N300 Wi-Fi Range Extender and your Wi-Fi router, to instantly extend your Wi-Fi coverage. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device.
  • Compact, convenient design
    The N300 Wi-Fi Range Extender is a compact device that is ideal for use at home or in a small office. The visual signal indicator LED makes it easy to find suitable placement location. Its space-saving wall-plug design easily saves you the hassle of dealing with a power adapter and cable. The discreet and unobtrusive appearance blends easily into the decor of your home or office.
D-Link DAP-1330 N300 Wi Fi Range Extender - Wi-Fi range extender - Wi-Fi
External
United Kingdom
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
5.55 cm x 3.4 cm x 7.7 cm
86.9 g
5.55 cm
3.4 cm
7.7 cm
86.9 g
United Kingdom
External
Wireless, wired
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Status, signal strength, WPS
Wi-Fi Protected Setup (WPS), Push Button Configuration (PBC)
Encryption Algorithm
WPA, WPA2
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 100Base-TX - RJ-45
UL, C-Tick, CB, IC, FCC
Internal power supply
10 - 90% (non-condensing)
