D-Link N QUAD GIG POE MAN ACCESS POIN W/ PLENUM CHASSIS
Quicklinx: 7392WS00 Mfr#: DAP-2690
  • IEEE 802.11n
The DAP-2690 is a dual-band wireless access point, designed to enable businesses of any size deploy wireless networks. Enclosed in a rugged, plenum-rated metal chassis, the DAP-2690 adheres to strict fire codes for placement in air passageways.
  • Versatile access point
    The DAP-2690 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual band wireless network. All four antennas are detachable and can provide optimal wireless coverage in both 2.4GHz (802.11g and 802.11n) and 5GHz (802.11a and 802.11n) bands. Enclosed in a plenum-rated metal chassis, the DAP-2690 adheres to strict fire codes for placement in air passageways. For advanced installations, this high-speed access point has integrated 802.3af Power over Ethernet (PoE) support, allowing installation of this device in areas where power outlets are not readily available.
  • Enhanced performance
    The DAP-2690 delivers reliable wireless performance with maximum wireless signal rates of up to 300Mbps in both the 2.4GHz and 5GHz wireless band. This, coupled with support for Wi-Fi Multimedia (WMM) Quality of Service feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-2690 to automatically prioritize traffic according to the level of interactive streaming, such as gaming or VoIP. The QoS feature also provides a drop-down menu option to select customized priority rules. Additionally, the DAP-2690 supports load balance features to ensure maximum performance by limiting the maximum number of users per access point.
  • Security
    To help maintain a secure wireless network, the DAP-2690 provides the latest in wireless security technologies by supporting both Personal and Enterprise versions of WPA and WPA2 with support for RADIUS server backend and a built-in internal RADIUS server allowing users to create their accounts inside. This access point also includes MAC address filtering, Wireless LAN segmentation, disable SSID broadcast, rogue AP detection, and wireless broadcast scheduling to further protect your wireless network. The DAP-2690 includes support for up to 8 VLANs per band for implementing multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication.
  • Multiple operation modes
    To maximize total return on investment, the DAP-2690 can be configured to optimize network performance based on any one of its multiple operation modes: access point, Wireless Distribution System (WDS) with access point, WDS/bridge (no AP broadcasting) and wireless client. With WDS support, network administrators can set up multiple DAP-2690s throughout a facility and configure them to bridge with one another while also providing network access to individual clients. Also included are advanced features such as load balancing, which optimizes high network traffic volume, and redundancy for fail-safe wireless connectivity. Additionally, the DAP-2690 offers spanning tree protocol support for greater efficiency and avoids broadcast storms when used in WDS mode.
  • Network management
    Network administrators have multiple options for managing the DAP-2690 including web (HTTP), Secure Sockets Later (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and telnet (bi-directional, eight-bit byte oriented communications facility). For advanced network management, administrators can use the D-Link AP Manager II or D-View SNMPv3 management module to configure and manage multiple access points from a single location. Also available is an AP array, allowing the management of a set of network devices as a single group for easy configuration and deployment. In addition, the DAP-2690 has a wireless scheduler feature for power saving.
D-Link AirPremier N Simultaneous Dual Band PoE Access Point with Plenum-rated Chassis DAP-2690 - radio access point - Wi-Fi
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Power Over Ethernet (PoE) Supported
PoE
19.1 cm x 19.9 cm x 3.7 cm
1 kg
Radio access point
Ruggedized Design
Indoor
19.1 cm
19.9 cm
3.7 cm
1 kg
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Network Access Protection (NAP)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
4
1 x 1000Base-T - RJ-45
Mounting Kit
Included
CSA, C-Tick, IC, FCC
PoE
10 - 90%
