D-Link mydlink Pro Wire-Free Camera Kit
Quicklinx: F036WS00 Mfr#: DCS-2802KT-EU
  • microSD Card
The mydlink Pro Wire-Free Camera Kit consists of two Wire-Free Cameras and a Hub which are ideal for Small Office/Home Office surveillance applications. The compact Wire-Free Cameras are suitable for day-time and night-time for both indoor and outdoor environments. It features built-in night vision, motion detection, and a free mobile app - so you can feel at ease when you're away from home.
  • Compact design, simple setup
    The Wire-Free Cameras are designed to be compact and discreet, so they can fit in with any decor, no matter where you put it. With the weatherproof design if can be placed indoors or out. The magnetic wall/ ceiling mount allows the cameras to be repositioned easily when necessary. Setting up the mydlink Pro Wire-Free Camera Kit is a breeze with the free mydlink app. Simply install the app on your mobile device and with a few taps, the app will guide you through the entire setup process.
  • Versatile feature set
    The mydlink Pro Wire-Free Camera Kit has all the features you need for monitoring your home. 100% wire-free allows the camera to be placed virtually anywhere in and around your home, whilst Full HD video images allow you to capture more details. Two-way audio on the cameras allows you to listen and talk back through the mydlink app. With mydlink cloud recording, videos can be saved to your private and personal cloud storage. The Hub supports up to four Wire-Free Cameras, so you can add additional cameras when needed. It also comes with integrated microSD card slot and USB port for external hard drives, should you wish to store videos and snapshots locally. The Wire-Free Camera's advanced PIR motion detection greatly reduces false alarms whilst automatically sending instant notifications to your mobile device. Integrated night vision allows you to see even in complete darkness. Each camera is powered by high capacity lithium batteries allowing months of operation without the need to recharge.
  • Anytime, anywhere access with mydlink Cloud Recording
    Enhanced with mydlink cloud recording support, the Wire-Free Camera Kit makes it easy and convenient for you to look after your family and check up on your home or office. With a mydlink cloud recording subscription, you can have peace of mind with your video recordings saved automatically to your private and personal cloud storage. Playback recordings from the cloud or download video clips to your mobile device from anywhere, anytime through the Internet. Access real-time live views of your cameras using the mydlink app and set automated schedules via your mobile device, no matter where you are.
D-Link DCS 2802KT - Camera Kit - network surveillance camera - with Hub (DCS-H100)
Network surveillance camera - fixed - outdoor, indoor - weatherproof
Packaged Quantity
2 (specifications are for single item)
Bundled with
Hub (DCS-H100)
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Wall mount, ceiling mount
6.6 cm x 8.5 cm x 8.5 cm
240 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
24 frames per second
Motion Detection
Video Modes
720p, 1080p
Optical Sensor Type
CMOS - 1/4" - 2 MP
Minimum Illumination
0 lux - B&W
Focal Length
1.9 mm
Lens Iris
F/2.2
IEEE 802.11n
Voltage
DC 5 V
Motion sensor, light sensor, Push Notification, integrated rechargeable battery, magnetic mount, WPA2, True Detect (PIR Thermal Sensing), motion detection
Environmental Parameters (operating)
-20 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
Packaged Quantity
Audio Support
Camera Mount Type
Wireless
6.6 cm
8.5 cm
8.5 cm
240 g
Europe
Bundled with
Hub (DCS-H100)
Camera
Colour - Day&Night - fixed - outdoor, indoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
720p, 1080p
0 lux - B&W
Infrared Distance
7.5 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
2 MP CMOS 1/4"
Lens Construction
Focal Length
1.9 mm
Lens Iris
F/2.2
Horizontal Field of View (degree)
115 - 64
Network Interface
IEEE 802.11n
Ports
USB
Supported Memory Cards
microSD Card
IP65
Power Requirements
DC 5 V - 2 A
Power adapter - external AC 120/230 V
Lithium Ion 23.5 Wh
Software Included
Premium Cloud Recording plan (12 months), myDlink Pro
Internet of Things (IoT)
Platform
IFTTT
Intelligent Assistant Compatible
Google Assistant, Alexa
-20 °C
45 °C
Relative Humidity (operating)
