The DNR-312L mydlink Network Video Recorder with HDMI is a dedicated standalone device that can simultaneously record videos from up to 9 D-Link network cameras in 1080p full HD resolution to its dedicated HDD storage.
A true standalone solution
The HDMI port on the DNR-312L can be connected to a 1080p high definition TV or monitor, making it a true standalone security solution. Plug a mouse into one of the USB ports and you can control what is displayed on the monitor, play back recorded video and use the digital pan/tilt/zoom functions. -
Mydlink technology on your mobile device
Empowered with mydlink technology, the DNR-312L enables users to remotely view and manage mydlink enabled devices from anywhere via a web browser using the mydlink website or the NVR's web interface. Additionally, using the mobile app means you can access and monitor your DNR-312L from your mobile devices. -
Versatile monitoring
Users have a variety of options for viewing and organizing camera footage on-screen. If multiple cameras have been set up in a property, users can simply drag and drop video from selected cameras to the viewing area. Camera names and recording statuses are clearly displayed for easy reference. Users can control pan/tilt/zoom (PTZ) functions from within the interface or by directly clicking on the video. -
Secure storage
Administrators may filter external connections to the NVR by IP address, limiting access and thus increasing security. Administrators may also choose access privileges for users by specifying the cameras they may access. The recorded data can be backed up to additional storage locations periodically or whenever needed. -
Extensive recording functionality
The DNR-312L's clear interface allows for easy configuration including compression, resolution, and frame rate for all connected cameras. Once the cameras have been set up, recordings can be made continuously, or according to a user-defined schedule. The NVR also provides event recording based on specific triggers such as when motion is detected. -
Convenient and reliable
The DNR-312L can manage multiple network cameras, providing direct access to view live video and play recorded data over the Internet from anywhere, anytime. Complete video management and the ability to playback and record new video simultaneously, the DNR-312L is an extremely convenient and effective video recorder. Moreover, the small size and portability of the DNR-312L make it easy to deploy in any location.
- mydlink Network Video Recorder with HDMI Output - standalone NVR - 9 channels
- NVR - 9 channels - networked
- IP Cameras Supported
- 9
- Compression Format
- MJPEG, MPEG-4, H.264
- 4.98 cm x 14.16 cm x 17.3 cm
- 425 g
- NVR
- Video Channels
- 9
- 9
- Package Content
- Manual, DVR, external power adapter, software
- Cables Included
- Network cable - 1 pcs.
- BSMI, FCC, RoHS
Security DVR
- Networked
- DDNS Support
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DDNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTPS, UPnP, IPv4
- ARP support, auto-uplink (auto MDI/MDI-X), IP address filtering, reset button, IPv4 support, DHCP client
- Video Output Ports
- HDMI x 1
- Audio Input Ports
- Mini-phone 3.5 mm x 1
- Audio Output Ports
- Network Port
- 10/100/1000Base-T
- Other Ports
- USB 2.0 x 2
- Power Consumption
- 30 Watt
- 4.98 cm
- 14.16 cm
- 17.3 cm
- 425 g
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
