Product
D-Link mydlink Home Smoke Detector
Quicklinx: CV05WS00 Mfr#: DCH-Z310
£48.01 ex VAT
£57.61 inc VAT
Protect your home and loved ones with the mydlink Home Smoke Detector. A built-in audio alarm alerts you whenever smoke is detected and sends a push notification to your smartphone or tablet when you're away from home. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. It works with other mydlink Home devices, such as the Smart Plug which can turn on a light when smoke is detected at night, or Siren to give you a loud audio warning either in a different part of your home or even at a location away from your home. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges.
  • mydlink Home Smoke Detector
    Protect your home and loved ones with the mydlink Home Smoke Detector. A built-in audio alarm alerts you whenever smoke is detected and sends a push notification to your smartphone or tablet when you're away from home. mydlink Home enables you to create a smart home without complicated set up, installation costs or monthly subscription charges. It's easy to set up and manage with the mydlink Home app, and connects to your router via the mydlink Home - Connected Home Hub. It works with other mydlink Home devices, such as the Smart Plug which can turn on a light when smoke is detected at night, or Siren to give you a loud audio warning either in a different part of your home or even at a location away from your home.
  • Peace of mind
    Smart smoke detector with built-in 85dB loud audio alarm that can also send a push notification to your smartphone and tablet.
  • Battery powered
    Battery powered with low battery indication via push notification through the mydlink Home app, allows you to stay informed on when the battery needs changing.
  • Your mydlink Home
    mydlink Home allows you to start with a single smart device and add more when you want to. The unique mydlink Home App for iOS and Android smartphone and tablet gives you control of all your other mydlink Home devices. You can even set up automation rules to make your home smarter.
  • Set up, control, monitor and protect your home
    The mydlink Home - Connected Home Hub acts as the link between your existing Wi-Fi network and all mydlink home devices.
mydlink Home Smoke Detector - smoke sensor
Smoke sensor
Functions
Siren
Wireless - Z-Wave
Supported Host Device OS
iOS, Android
12 cm x 5.3 cm x 12 cm
Smoke sensor
Functions
Siren
Wireless - Z-Wave
iOS, Android
Push notification, built-in alarm
CR123A lithium battery
Encryption Algorithm
128-bit AES
FCC
12 cm
5.3 cm
12 cm
130 g
49 °C
10 - 85% (non-condensing)
Type: Smoke Detector
Brand: D-Link
Price Range Ex VAT: 0 - 50
