D-Link mydlink Home Smart Home Security Kit
Quicklinx: CFZ1WS00 Mfr#: DCH-107KT
£175.98 ex VAT
£211.17 inc VAT
This convenient security bundle lets you protect and monitor your home from anywhere. The Smart Home Security Kit includes a Connected Home Hub, a Door & Window Sensor, a Siren with optional battery back-up and a Monitor HD. These devices talk to each other and with the mydlink Home smartphone and tablet app you can decide what it is you would like them to do.
  • Your mydlink Home
    mydlink Home allows you to start with this convenient starter kit and add more when you want to. You can even setup automation rules to make your home smarter.
  • Door and window sensor
    Detect when a door or window is opened or closed as well as monitor room temperature. Know when people come and go in your home or monitor off-limit areas like medicine cabinets.
  • mydlink Home siren
    It alerts you when a linked mydlink Home sensor is triggered. Equipped with different sounds, you can customize your smart home by selecting the appropriate sound effect or alarm whenever a different event occurs.
  • View from anywhere with monitor HD
    View securely over the Internet through your smartphone or tablet. Monitor your home in HD. See everything in detail, even when zoomed in. Built-in night vision function allows you to see even in complete darkness. It alerts you with push notification whenever motion or sound is detected.
mydlink Home Smart Home Security Kit - home security system
Home security system
Package Content
Door and window sensor, central controller, camera, siren
Wireless - Wi-Fi, Z-Wave
Supported Host Device OS
iOS, Android
Camera
CMOS 1/4" - Max Resolution 1280 x 720 - audio - Day&Night
Camera Zoom
4x digital zoom
Package Content
Components
Central controller , Siren , Door and window sensor , Camera
Wireless - Z-Wave, Wi-Fi
iOS, Android
Push notification, 6 different siren sounds
Camera
Image Sensor
CMOS 1/4"
Lens Aperture
F/2.4
Focal Length
2.38 mm
Day & Night Functionality
Digital Zoom
4
Audio Support
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Text stamp, Text Caption Overlay
Encryption Algorithm
128-bit AES
FCC Class B certified, C-Tick, FCC, LVD
Dimensions & Weight Details
Central controller: 10 cm x 10 cm x 11 cm x 180 g , Siren: 11 cm x 11 cm x 1.9 cm x 125 g , Camera: 5.8 cm x 8.45 cm x 12.49 cm x 160 g , Magnet: 5 cm x 1.2 cm x 1 cm , Door and window sensor: 9.6 cm x 2.8 cm x 2.3 cm
20 - 90% (non-condensing)
Type: Home security system
Brand: D-Link
Price Range Ex VAT: 150 - 300
