Your basket is empty
D-Link mydlink Home SMART Home HD Starter Kit
Control, monitor and automate your home from anywhere!
Quicklinx: B8FBWS00 Mfr#: DCH-100KT/B
  • Smart Plug (DSP-W215)
  • Wi-Fi Motion Sensor (DCH-S150)
  • Monitor HD (DCS-935L)
This clever little starter kit gives you the ability to set, control, monitor and automate your home from anywhere. The Smart Home HD Starter Kit includes a Smart Plug (DSP-W215), a Wi-Fi Motion Sensor (DCH-S150) and a Monitor HD (DCS-935L).
These devices talk to each other and with the mydlink Home smartphone and tablet app you can decide what it is you would like them to do. This is clever stuff implemented to make your life easier and safer with added peace of mind. It is smart home technology at its most futuristic.
Easy To Set Up
Simply download the mydlink Home app and the step by step setup wizard will help you set up all the devices in the kit
Do-It-Yourself Simple, No Installation Fees, No Monthly Charges
Your mydlink™ Home
mydlink™ Home allows you to start with this convenient starter kit and add more when you want to. The unique mydlink™ Home App1 for iOS and Android smartphone and tablet puts you in control of all your mydlink™ Home smart devices. You can even setup automation rules to make your home smarter.
mydlink Home Smart Plug - DSP W215
Turn Devices On/Off with Smart Plug
Instantly turn devices on or off from your iOS or Android smartphone or tablet using the mydlink™ Home app, wherever you are Create on/off schedules to have your appliances work for you when you want them to. The integrated thermal sensor automatically turns off overheating power sockets, giving you peace of mind2. Automatic alerts to notify you when an appliance has been: Turned on/off, Power consumption limit is exceeded, If the appliance malfunctions and overheats
mydlink Home Monitor HD - DCS 935L
View From Anywhere with Monitor HD Monitor your home in HD 720p. See everything in detail, even when zoomed in. Alerts you with push notification whenever motion or sound is detected Built-in night vision function allows you to see up to 5 metres even in complete darkness
mydlink Home Motion Sensor - DCH S150
Enhanced Motion Detection with Wi-Fi Motion Sensor The passive Infrared (PIR) motion sensor greatly reduces false alarms to ensure you are alerted only when needed Motion detection up to 8 metres (100° horizontal / 80° vertical). Automatic alerts to notify you when motion is detected
mydlink Smart Home HD Starter Kit - home automation / security system
Home automation / security system
Functions
Energy use monitor, turn electronics on/off
Package Content
Motion sensor, smart plug, camera
Wireless - 802.11b/g/n
Supported Host Device OS
iOS, Android
Camera
CMOS 1/4" - Max Resolution 1280 x 720 - audio - Day&Night
Camera Zoom
4x digital zoom
Functions
Package Content
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
iOS, Android
Thermal protection, energy usage statistics, push notification, power scheduling Wi-Fi Protected Setup (WPS), overheat protection
Camera
Image Sensor
CMOS 1/4"
Lens Aperture
F/2.4
Focal Length
2.38 mm
Day & Night Functionality
Digital Zoom
4
Audio Support
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
8 m
Encryption Algorithm
WPA, WPA2
Nominal Voltage
AC 100/240 V
UL, FCC
Dimensions & Weight Details
Smart plug: 9.65 cm x 6.2 cm x 7.67 cm x 173 g , Motion sensor: 5.8 cm x 5.4 cm x 4.35 cm x 80 g , Camera: 5.8 cm x 8.45 cm x 12.49 cm x 160 g
