The mydlink Home Monitor HD allows you to monitor your home, whenever, from wherever. See everything in full color high definition 720p with sound. The built-in night vision allows you to see up to 5 meters even in complete darkness. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
Monitor everything
This high-definition camera delivers high-quality video for remote viewing on the tablet or smartphone you already own. -
Mydlink Home app-enabled
Use the free mydlink Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world. -
Wireless connectivity
Connect the Monitor HD to your Wireless home network, easily and conveniently, using one-button setup. -
Motion detection with night vision
Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor HD sees. -
HD clarity
See all the details with high definition 720p color images with sound. -
Easy to setup
Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi protected setup. No additional control hub needed. -
High definition
Monitor your home in crystal clear HD 720p. See everything in detail, even when zoomed in. -
See in the dark
Built-in night vision function allows you to see up to 5 meters even in complete darkness. -
Motion and sound detection
Alerts you with push notification whenever motion or sound is detected.
- mydlink Home Monitor HD - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 5.8 cm x 8.45 cm x 12.49 cm
- 160 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 0 lux - IR - F2.4
- Focal Length
- 2.38 mm
- Focus Adjustment
- (min distance 434 mm)
- Lens Iris
- F/2.4
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Voltage
- DC 5 V
- Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wireless
- 5.8 cm
- 8.45 cm
- 12.49 cm
- 160 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Digital Zoom
- 4
- Exposure Range
- 1/7.5 sec - 1/24000 sec
- 0 lux - IR - F2.4
- Infrared Distance
- 5 m
- Digital Video Capture Resolution
- 1280 x 720, 720 x 480, 640 x 480, 320 x 240, 800 x 600
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 2.38 mm
- Lens Iris
- F/2.4
- Min Focus Distance
- 434 mm
- Horizontal Field of View (degree)
- 78.44
- Vertical Field of View (degree)
- 47.9
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RNCP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, PPPoE
- Supported Memory Cards
- microSD Card, microSDHC Card
- FCC Class B certified, C-Tick, LVD
- Power Requirements
- DC 5 V
- Power Device
- 3.5 Watt
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
