The mydlink Home Monitor 360 allows you to monitor your home, whenever, from wherever. Not only does it pan and tilt to cover wider areas, the built-in night vision allows you to see up to 8 meters even in complete darkness. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
Mydlink home app-enabled
Use the free mydlink home app to view what your Monitor 360 sees, using your tablet or smartphone to control it wherever you are in the world. -
Wireless connectivity
The latest in Wireless technology gives you increased speed, range and reliability, allowing for placement anywhere in your home where you have wireless coverage. -
Motion detection with night vision
Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor 360 sees. -
Easy to setup
Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi Protected Setup. No additional control hub needed. -
Pans and tilts
Remote control, motorized pan and tilt allow you to monitor wider areas of your home with a single camera. -
See in the dark
Built-in night vision function allows you to see up to 8 meters even in complete darkness. -
Motion detection
Alerts you with push notification whenever motion is detected.
- mydlink Home Monitor 360 - network surveillance camera
- Network surveillance camera - pan / tilt
- Audio
- Yes: built-in microphone
- 10.127 cm x 10.235 cm x 13.36 cm
- 292.4 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 640 x 480
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/5"
- Minimum Illumination
- 0 lux - IR - F2.0
- Focal Length Control
- Fixed focal
- Focal Length
- 2.2 mm
- Lens Iris
- F/2.0
- Panning Range (degree)
- -170 to +170
- Tilting Range (degree)
- -25 to +95
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 12 V
- Motion sensor, date/time stamp, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, Wi-Fi Protected Setup (WPS), text stamp, notification picture to E-mail, notification picture to FTP, password protection
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 85% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 10.127 cm
- 10.235 cm
- 13.36 cm
- 292.4 g
Camera
- Colour - Day&Night - pan / tilt
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 640 x 480
- Digital Zoom
- 4
- Exposure Range
- 1/15 sec - 1/15000 sec
- 0 lux - IR - F2.0
- Infrared Distance
- 8 m
- Digital Video Capture Resolution
- 640 x 480, 320 x 240, 160 x 112
- Frame Rate (max)
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/5"
Lens Construction
- Fixed focal
- Focal Length
- 2.2 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 66.22
- Vertical Field of View (degree)
- 49.08
Panning
- Range (degree)
- -170 to +170
Tilting
- Range (degree)
- -25 to +95
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
- C-Tick, FCC
- Power Requirements
- DC 12 V
- Power Device
- Power adapter - external 8.64 Watt
- OS Required
- Microsoft Windows Vista / XP / 7 / 8, Android 4.0 or later, Apple iOS 6.0 or later
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
