D-Link mydlink Home Battery Motion Sensor (mydlink Connected Home)
Quicklinx: CFZ8WS00 Mfr#: DCH-Z120
The mydlink Home Motion Sensor detects motion within its field of view, providing you with a trigger for automating your home. Integrating with D-Link's HNAP protocol, the Motion Sensor connects seamlessly with your Connected Home Hub, guaranteeing compatibility and getting your smart home network up and running right away.
  • Peace of mind
    Be alerted instantly on your smartphone or tablet whenever motion is detected in your home. Battery powered means that it can be placed virtually anywhere within your home.
  • 3-in-1 sensor
    Monitor temperature, light as well as motion.
  • Your mydlink Home
    mydlink Home allows you to start with a single smart device and add more when you want to. The unique mydlink Home App for iOS and Android smartphone and tablet gives you control of all your other mydlink Home devices. You can even set up automation rules to make your home smarter.
  • Set up, control, monitor and protect your home
    The mydlink Home - Connected Home Hub acts as the link between your existing Wi-Fi network and all mydlink home devices.
mydlink Home Battery Motion Sensor - multipurpose sensor - Z-Wave
Multipurpose sensor
Sensor Type
Temperature, ambient light, motion
Wireless - Z-Wave
Frequency Band
868.4 MHz
Europe
9.6 cm x 2.8 cm x 2.3 cm
Multipurpose sensor
Sensor Type
Wireless - Z-Wave
Frequency Band
868.4 MHz
Tamper protection
CR123A lithium battery
Europe
Encryption Algorithm
128-bit AES
FCC
9.6 cm
2.8 cm
2.3 cm
-10 °C
20 - 90% (non-condensing)
