D-Link Indoor 802.11a/b/g/n Concurrent Dual-Band Unified AP
Quicklinx: 7XCJWS00 Mfr#: DWL-6600AP
  • IEEE 802.11n
The DWL-6600AP is designed to be the best-in-class indoor Access Point for business environments. With high data transmission speeds, load balancing features, it can be deployed as a standalone wireless Access Point or used as the foundation for a managed wireless network.
  • Enhanced performance
    The DWL-6600AP delivers reliable wireless performance with maximum wireless signal rates of up to 300 Mbps in either the 2.4 GHz or 5 GHz mode. Support for Wi-Fi Multimedia (WMM) Quality of Service features makes the DWL-6600AP an ideal access point for audio, video, and voice applications. In addition, the load balancing feature ensures maximum performance and best service quality in the wireless environment.
  • Self-configuring cluster
    For small businesses that need to deploy multiple access points but lack the resources to tackle the complicated task of network management, the DWL-6600AP's self-configuring cluster feature offers the ideal solution. When a small number of DWL-6600APs is deployed on the network, they may be configured to form a self-configuring cluster.
  • Security
    The DWL-6600AP supports the Wi-Fi security, including WEP, WPA, WPA2, and 802.1x. In addition, the DWL-6600AP supports up to 16 virtual Access Points (VAP) per radio, for a total of 32 VAPs, which allows the administrator to assign different access privileges to different groups of users. When station isolation is enabled, the AP blocks communication between wireless clients on the same radio and VAP.
  • Convenient installation
    With an embedded antenna and simple styled exterior, the DWL-6600AP can be installed on a wall or ceiling and blends in with most interior decorations in an office. Enclosed in a plenum-rated chassis, the DWL-6600AP adheres to strict fire codes for placement in air passageways. For easy installation, the DWL-6600AP has integrated 802.3af Power over Ethernet (PoE) support, allowing installation of this device in areas where power outlets are not readily available.
D-Link Wireless N Dualband Unified Access Point DWL-6600AP - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
15.6 cm x 15.6 cm x 7.8 cm
0.5 kg
Radio access point
15.6 cm
15.6 cm
7.8 cm
0.5 kg
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, WLAN, LAN
128-bit encryption, 64-bit encryption, power over Ethernet (PoE), load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, MIMO technology, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), Multiple SSID support, rogue access point detection
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 4 x aerial
FCC Class B certified, C-Tick
PoE
10 - 90% (non-condensing)
7XCJ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
7XCJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.21
7XCJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.80
7XCJ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.20
