DWL-3600AP is a highly manageable access point, capable of high data transmission speeds, it integrates seamlessly into any network and scales to meet future wireless demands.
High performance
The DWL-3600AP's 2 x 2 MIMO 2.4 GHz radio delivers up to 300 Mbps of network throughput. In addition, the DWL-3600AP features RadioProtect technology, which ensures all users receive an adequate level of service even in an environment where many users are accessing the network through legacy 802.11b and 802.11g devices. -
Self-configuring cluster
For small businesses that need to deploy multiple access points but lack the resources to tackle the complicated task of network management, the DWL-3600AP's self-configuring cluster feature offers the ideal solution. When a small number of DWL-3600APs is deployed on the network, they may be configured to form a self-configuring cluster. -
Security
The DWL-3600AP supports the Wi-Fi security, including WPA, WPA2, and 802.1x. In addition, the DWL-3600AP supports up to 16 Virtual Access Points (VAP), which allows the administrator to assign different access privileges to different groups of users. -
Automatic RF management
When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. When a DWL-3600AP senses a neighbor nearby, it will automatically select a non-interfering channel. This greatly reduces RF interference and allows the administrator to deploy APs more densely. -
Quality of Service
The DWL-3600AP is WMM-certified, so in the event of network congestion, time-sensitive traffic can be given priority ahead of the rest of traffic. Furthermore, when a number of DWL-3600APs are in close proximity with each other, an access point will refuse new association requests once its resources are fully utilized. Instead, the association request will be picked up by a neighboring unit. This feature ensures that no single AP is overburdened while others nearby sit idle.
- D-Link Wireless N Unified Access Point DWL-3600AP - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 20.3 cm x 20.3 cm x 4.8 cm
- 0.64 kg
- 20.3 cm
- 20.3 cm
- 4.8 cm
- 0.64 kg
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, WLAN, LAN
- 128-bit encryption, 64-bit encryption, power over Ethernet (PoE), load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, MIMO technology, Wi-Fi Multimedia (WMM) support, SpectraLink Voice Priority (SVP) support, Quality of Service (QoS), Multiple SSID support, rogue access point detection
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
- Directivity
- Omni-directional
- Gain Level
- 4.7 dBi
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- FCC
- PoE
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
