The DCS-2330L HD Wireless N Day/Night Outdoor Cloud Camera is the perfect solution for monitoring an outdoor area 24 hours a day from anywhere. This mydlink-enabled network camera is built to last with rugged metal housing while the megapixel image sensor and infrared night vision give you high-quality resolutions up to 720p HD even in complete darkness.
The DCS-2330L is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail, so you can capture important details often missed by lower resolution cameras. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera's video so you can survey a large area easily.
An infrared cut removable (ICR) filter is also built into the DCS-2330L, which blocks infrared light during the day for improved image quality. At night, it moves out of the way to use all available light for low-light surveillance, and paired with the IR LED illuminator, this camera can monitor an area even in complete darkness.
Connecting a camera on your network and accessing it has traditionally required complex configuration. mydlink makes it easy to access your camera from wherever you are, whenever it's convenient for you. Using the free mydlink Lite app for iOS and Android smartphones and tablets, you can connect and setup your mydlink camera without turning on a computer. A step-by-step guide has your camera up and running in a matter of minutes. Through the mydlink Lite app, you can set up a free mydlink account which allows you to view and manage your camera from any Internet connected device. If you have more than one camera, you can add it to your existing mydlink account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the free mydlink Lite app for your iPhone or Android device and you can quickly and easily view your camera feed from anywhere with a wireless or 3G/4G LTE connection. You can even access videos recorded onto the included SD card. Thanks to this app, you can monitor on-the-go even if you don't have access to a computer.
If you have a mydlink-enabled Cloud Router, setting up and configuring your DCS-2330L is a snap, thanks to Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your Cloud Router with an Ethernet cable - the camera will automatically be added to your account.
Specially built for outdoor use, the DCS-2330L has an IP65 weatherproof housing that protects it from the elements. Wireless N connectivity means you can put it anywhere within range of your wireless network, giving you the freedom to install it right where you need camera coverage. A passive infrared (PIR) motion sensor provides enhanced motion detection to minimize false alarms.
This mydlink camera includes a MicroSD card slot and a pre-installed 16Gb MicroSD card to record audio and video directly onto the camera, without the need of a computer. You can setup the camera to record only when motion is detected for up to 7 days2 via the camera's intuitive web interface. Once the MicroSD card is at full capacity, older footage will be recorded over. The camera can also send e-mail alerts whenever motion is detected. All these features can be easily configured via the web-based configuration, which makes this camera a truly comprehensive home monitoring system.
If you want to expand your surveillance options, D-Viewcam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Outdoor HD wireless network camera
The D-Link (DCS-2330L) is an Outdoor HD Wireless Network Camera, with an outdoor-ready design, wireless connectivity for easy setup and flexible placement, HD 720p surveillance recording, and cloud services-enabled remote management, the cloud camera provides a perimeter of protection so you can keep an eye on what matters most. -
Outdoor-ready coverage
D-Link's Outdoor HD Wireless Network Camera is outdoor-ready with a IP65 resistant casing equipped to handle dust and water contact. It also features a versatile -13 °F to 113 °F operating temperature range so you can keep an eye on the bigger picture - whatever the weather, whatever the season. -
720p HD for superior image quality
The D-Link Outdoor HD Wireless Network Camera (DCS-2330L) delivers the confidence of 720p HD video clarity, ensuring rich detail and crisp image quality for your surveillance recording. And with integrated night-vision and PIR motion-sensing technology, the DCS-2330L remains vigilant 24 hours a day, whether you're there or not. -
Make easy setup even easier - with zero configuration
Connecting your D-Link camera with any router is easy. Zero configuration automatically configures and intelligently syncs your D-Link camera to your mydlink account - it is as easy as connect and view! -
Record directly to microSD card
The camera features a microSD card slot for hassle-free recording and playback. No additional PC, network video recorder, or other device is needed. Enjoy the easy and efficient alternative for recording and storing video.
- D-Link DCS-2330L - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: built-in microphone
- 9.3 cm x 6.6 cm x 14.05 cm
- 255 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 3.45 mm
- Lens Iris
- F/2.0
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable
- Voltage
- DC 5 V
- Motion sensor, date/time stamp, sharpness control, saturation control, brightness control, contrast control, infrared cut filter, Privacy Mask Function, microSDHC card slot, Wi-Fi Protected Setup (WPS), text stamp, Cloud storage capability, digital PTZ function, passive infrared sensor
- 2-year warranty
- Environmental Parameters (operating)
- -25 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 9.3 cm
- 6.6 cm
- 14.05 cm
- 255 g
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Digital Zoom
- 10
- 0 lux - IR
- Infrared Distance
- 5 m
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 3.45 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 57.8
- Vertical Field of View (degree)
- 37.8
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, QOS, CoS
- Supported Memory Cards
- microSD Card, microSDHC Card
- Cables Included
- 1 x network cable
- FCC Class B certified, C-Tick, IP65
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 5.5 Watt
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7, Windows 8
- Limited warranty - 2 years
- -25 °C
- 45 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
