D-Link Full HD WDR Day & Night Outdoor Dome Network Camera
Quicklinx: 9898WS00 Mfr#: DCS-6513/B
The D-Link DCS-6513 Full HD WDR Day & Night Outdoor Dome Network Camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 3 megapixel progressive scan CMOS sensor with a motorized P-Iris lens and onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for accessories.
  • High-quality video
    The DCS-6513 is equipped with a P-Iris lens that controls the iris with extreme precision. Its built-in stepping motor maintains the Iris opening at an optimal level at all times, resulting in superior image quality, clarity, and depth of field, so you can see every minute detail of the area being monitored. The remote focus function eliminates the need for manual focusing at the camera's position and allows you to make adjustments from any computer. To maximize bandwidth efficiency and improve image quality, the DCS-6513 provides real-time video compression using the H.264, MPEG-4, and MJPEG codecs, and supports three separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory. Furthermore, bandwidth requirements can be adjusted in real-time over the network, and recorded video files can be saved to network attached storage (NAS) device or Micro SD card.
  • Continuous monitoring
    The DCS-6513's WDR image enhancement gives you improved image quality in environments with uneven or difficult lighting, so you can identify subjects that are backlit or in brightly lit areas. In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-6513 also has built-in IR LED illuminators with a 20 meter range, allowing the camera to keep watch even in complete darkness. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day.
  • Flexible connectivity options
    The DCS-6513 has a built-in 802.3af compliant PoE module that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the included digital input and output connector enables connections to external devices such as IR sensors, switches and alarm relays.
D-Link DCS 6513 Full HD WDR Day & Night Outdoor Dome Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
Audio
Yes: two-way audio capability
15.179 cm x 19.18 cm x 12.7 cm
1.53 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
3 x
Max Resolution
2048 x 1536
Optical Sensor Type
CMOS - 1/2.8" - 3 MP
Minimum Illumination
0 lux - IR , 0.5 lux - colour - F1.2
Focal Length Control
Vari-focal
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, Power over Ethernet, contrast control, Wide Dynamic Range (WDR), SDHC-card slot, ONVIF support, built-in LED illuminator, P-Iris control
Environmental Parameters (operating)
-40 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Dome
Wired
15.179 cm
19.18 cm
12.7 cm
1.53 kg
Camera
Colour - Day&Night - fixed - outdoor - vandal / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Digital Zoom
10
Supported Image Formats
JPEG
Image Sensor
3 MP CMOS 1/2.8"
Lens Construction
Vari-focal
Optical Zoom
3 x
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2
Horizontal Field of View (degree)
31.6 - 96.4
Vertical Field of View (degree)
17.7 - 51.2
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x microphone - input , 1 x speakers - output
C-Tick, FCC, IP67, IK10
Power Requirements
DC 12 V / PoE
Power adapter - external AC 120/230 V (50/60 Hz) 10.5 Watt
Software Included
Drivers & Utilities
Microsoft Windows 2000/XP/Vista/7, Windows 8
-40 °C
50 °C
Relative Humidity (operating)
9898 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
