The D-Link DCS-6314 Full HD WDR Varifocal Day & Night Outdoor Dome Network Camera is a high definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 2 megapixel progressive scan CMOS sensor with onboard WDR image enhancement to deliver truly superior quality video in all conditions.
- D-Link DCS 6314 Full HD WDR Varifocal Day & Night Outdoor Dome - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
- Audio
- Yes: two-way audio capability
- 12.8 cm x 12.8 cm x 12.32 cm
- 1.11 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 4.3 x
- Max Resolution
- 1920 x 1080
- Optical Sensor Type
- 1/2.8"
- Minimum Illumination
- 0.2 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
- Focal Length
- 2.8 mm - 12 mm
- Lens Iris
- F/2.4
- Panning Range (degree)
- 340
- Tilting Range (degree)
- 75
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Motion sensor, SD-card slot, Power over Ethernet, built-in IR illuminator, Virtual Pan/Tilt/Zoom
- Environmental Parameters (operating)
- -30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Wired
- 12.8 cm
- 12.8 cm
- 12.32 cm
- 1.11 kg
Camera
- Colour - Day&Night - fixed - outdoor - vandal / weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Capture
- 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps , 800 x 450 @ 30 fps , 640 x 360 @ 30 fps , 480 x 270 @ 30 fps , 320 x 176 @ 30 fps , 176 x 144 @ 30 fps , 1440 x 1080 @ 30 fps , 1280 x 960 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps , 176 x 144 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- 1/2.8"
Lens Construction
- Optical Zoom
- 4.3 x
- Focal Length
- 2.8 mm - 12 mm
- Lens Iris
- F/2.4
- Horizontal Field of View (degree)
- 31.2 - 96.5
- Vertical Field of View (degree)
- 17.8 - 117.5
Panning
- Range (degree)
- 340
Tilting
- Range (degree)
- 75
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, QOS, CoS
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Supported Memory Cards
- SDHC Memory Card
- C-Tick, FCC
- Power Requirements
- DC 12 V / PoE
- Power Device
- Power adapter - external 10 Watt
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
