D-Link Full HD Mini Fixed Dome Network Camera
Quicklinx: C1ZVWS00 Mfr#: DCS-6210/E
  • SDHC Memory Card
The DCS-6210 comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. It's 3 axis lens mounting allows you to position it perfectly, while its motion detection capabilities allow it to automatically record video and send you a notification when motion is detected.
  • Built for tough environments
    Specially designed for use in challenging environments the DCS-6210 has a toughened metal, industry-certified IK-10 and IP-66 housing. This means that it is able to withstand sudden high impact, and adverse weather conditions. Additionally, the DCS-6210 carries a Power over Ethernet (PoE) port which allows you to connect the camera to your network and power it through a single cable. This both expands and simplifies your deployment options by doing away with the need for a nearby power outlet, making deployment on ceilings much easier.
  • Surveillance in Full High Definition
    The DCS-6210 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 1080p Full HD. This gives you sharp, high-resolution pictures and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera's video so you can survey a large area easily.
  • A complete, expandable surveillance solution
    The DCS-6210 is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device.
D-Link DCS 6210 Full HD Mini Fixed Dome Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
Audio
Yes: built-in microphone
11.55 cm x 5.16 cm x 10.68 cm
412.2 g
Wired
Camera
Max Resolution
1920 x 1080
Motion Detection
Optical Sensor Type
CMOS - 1/2.7"
Focal Length
4.3 mm - 4.3 mm
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Manual white balance, date/time stamp, sharpness control, saturation control, brightness control, Power over Ethernet, contrast control, ONVIF support, Motion Detection Technology, Privacy Mask Function
Environmental Parameters (operating)
-25 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Dome
Wired
11.55 cm
5.16 cm
10.68 cm
412.2 g
Europe
Camera
Colour - fixed - outdoor - vandal / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Digital Zoom
10
Supported Image Formats
JPEG
Image Sensor
CMOS 1/2.7"
Lens Construction
Focal Length
4.3 mm - 4.3 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
79
Vertical Field of View (degree)
43
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, 3GPP/ISMA, CoS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Supported Memory Cards
SDHC Memory Card
C-Tick, FCC
Power Requirements
PoE
7.8 Watt
-25 °C
50 °C
Relative Humidity (operating)
C1ZV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
