The DCS-7413 bullet camera is a full-featured solution for professional surveillance and security, equipped with a two-megapixel progressive scan CMOS sensor offering low noise and high sensitivity for surveillance applications. The DCS-7413 includes features such as full HD resolution, and built-in IR LEDs for increased visibility at night. Using an ARM SoC, the camera provides excellent real-time video quality and can handle multiple video streams with different configurations activated simultaneously to address varying requirements for live viewing and recording. The DCS-7413 also includes input and output ports for connectivity to external devices such as PIR sensors, switches and alarm relays.
- D-Link DCS 7413 Full HD Day & Night Outdoor Network Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- 1.92 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Optical Sensor Type
- CMOS - 1/2.7" - 2 MP
- Minimum Illumination
- 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 4.3 mm
- Lens Iris
- F/2.0
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Motion sensor, date/time stamp, sharpness control, saturation control, brightness control, Power over Ethernet, sunshield, contrast control, SDHC-card slot, heater, ONVIF support, built-in cooling fan, infrared cut filter, built-in IR illuminator
- Environmental Parameters (operating)
- -40 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired
- 1.92 kg
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 10
- 0 lux - IR
- Supported Image Formats
- JPEG
Image Sensor
- 2 MP CMOS 1/2.7"
Lens Construction
- Fixed focal
- Focal Length
- 4.3 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 73.5
- Vertical Field of View (degree)
- 42.5
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Sunshield
- C-Tick, FCC, IP66
- Power Requirements
- DC 12 V / PoE
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 11.2 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
