D-Link DXS-3400-24TC Managed L3 Gigabit Ethernet (10/100/1000) Switch
Quicklinx: CQH6WS00 Mfr#: DXS-3400-24TC
Type: 10 Gigabit Ethernet
Ports: 24
Managed: Yes
£5,373.89 ex VAT
£6,448.66 inc VAT
The DXS-3400 Series switches feature a modular fan and power supply design for a high availability architecture. The hot-swappable design means that fans and power supplies can be replaced without affecting switch operation. Physical and virtual switch stacking allow the switches to be managed from a single IP address and provide redundancy for connected devices. The Switch Resource Management (SRM) feature allows the hardware table size to be changed, so that switch functions can be optimized based on the use of the switch. The DXS-3400 Series switches come with 3 modes; IP Mode, LAN Mode and L2 VPN Mode, which modify the size of the Layer 2 and 3 tables for optimum efficiency.
The DXS-3400 Series switches include feature rich software which satisfies the needs of Small Medium Business, Small Medium Enterprise, and campus users. It supports a wide range of Layer 2 and 3 functions such as VLANs, inter-VLAN routing, multicasting, Quality of Service (QoS), Virtual Router Redundancy Protocol (VRRP), Routing Information Protocol (RIP) v1/2, Next Generation RIP (RIPng), Policy-Based Routing (PBR), and security features. The DXS-3400 Series also includes an easy-to-use web interface and an industry standard CLI for improved management.
  • High availability and flexibility
  • Feature rich software
  • Lossless Ethernet
    Data Center Bridging (DCB) is an essential set of enhancements to Ethernet for networking in data center environments. The DXS-3400 Series switches support several core components of Data Center Bridging (DCB) such as IEEE 802.1Qbb, IEEE 802.1Qaz, and IEEE 802.1Qau. IEEE 802.1Qbb (Priority-based Flow Control) provides flow control on specific priority to ensure there is no data loss during network congestion. IEEE 802.1Qaz (Enhanced Transmission Selection) manages the allocation of bandwidth amongst different traffic classes. IEEE 802.1Qau (Congestion Notification) provides congestion management for data flows within network domains to avoid congestion.
  • Energy efficient
    The DXS-3400 Series switches feature front-to-back airflow which facilitates the building of energy-efficient data centers. The front-to-back airflow optimizes air circulation inside the rack, allowing hot and cold isles in data centers, increasing energy efficiency in comparison to a mix of front-to-back and side-to-side airflow. The switches also feature in-built smart fans; internal heat sensors monitor and detect temperature changes, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run more slowly, reducing the switch's power consumption and noise.
D-Link DXS 3400-24TC - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 Lite - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
20 x 10GBase-T + 4 x combo 10 Gigabit SFP+
Performance
Switching capacity: 480 Gbps , Forwarding performance: 357.12 Mpps , Stacking bandwidth: 80 Gbps
IGMP groups: 256 , MLD groups: 256 , ARP entries: 512
MAC Address Table Size
48K entries
Jumbo Frame Support
12KB
Routing Protocol
RIP-1, RIP-2, VRRP, GRE, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, VPN support, ARP support, load balancing, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, firmware upgradable, sFlow, PIM snooping, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, enhanced transmission selection, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, Unicast Reverse Path Forwarding (URPF), Uni-Directional Link Detection (UDLD), Deficit Weighted Round Robin (DWRR), LLDP support, DHCP relay, Data Center Bridging (DCB), DHCP client, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Strict Priority (SP), 4MB packet buffer, Two Rate Three Color Marking (TRTCM), DiffServ Code Point (DSCP) support, Ethernet Ring Protection Switching (ERPS), hot swappable 3 fans, Single Rate Three Color Marking (SRTCM), system log, Head of Line Blocking Prevention, Deficit Round Robin (DRR), Priority-Based Flow Control (PFC), Link Aggregation
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau
AC 120/230 V (50/60 Hz) 2 A
Power Redundancy
Optional
44.1 cm x 38 cm x 4.4 cm
7.6 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
48K entries
Jumbo Frame Support
12KB
Max Units In A Stack
4
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
24 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x console RJ-45 , 1 x console (mini-USB) , 1 x management (Gigabit LAN) RJ-45 , 1 x USB
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Electric Current Required
2 A
163.62 Watt
VCCI, C-Tick, BSMI, cUL, CB, CCC, FCC
44.1 cm
38 cm
4.4 cm
7.6 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CQH6 D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver In Stock £23.64
CQH6 D-Link SFP+ Direct Attach Stacking Cable, 1M In Stock £165.07
CQH6 D-Link 1-Port Mini GBIC Module for 1000BaseLX (LC Duplex) In Stock £31.95
Ports: 24
Managed: Yes
Brand: D-Link
Price Range Ex VAT: £1500+
