D-Link DXS-1210-10TS 8-Port 10 Gigabit (10GbE) Smart Switch
Quicklinx: B8GSWS00 Mfr#: DXS-1210-10TS
Type: 10 Gigabit Ethernet
Ports: 8
Data Transfer Rate: 10Gbps
Managed: Yes
POE: No
Hurry, only 2 left in stock!
£654.88 ex VAT
£785.85 inc VAT
The D-Link DXS-1210-10TS 8-Port 10 Gigabit (10GbE) Smart Switch is a cost effective 10 GbE switch capable of servicing a range of network needs in any business. Supporting 10GBASE-T/SFP+ combo ports, this D-Link DXS-1210 -10TS provides connection flexibility across a network allowing easier network integration. With high performance and low latency this DXS-1210-10TS can fulfill the needs for virtualisation, cloud services and server-to-server applications making it perfect for SMB customers.
Energy Saving
Incorporating D-Link Green technology, this switch is capable of power-saving without sacrificing operational performance or functionality. This switch feature built-in smart fans; internal heat sensors monitor and detect temperature changes, and react accordingly by utilising different fan speeds for different temperatures. At lower temperatures, the fans will run slower, reducing the switch's power consumption and noise.
Link status drastically reduces power consumption by automatically toggling ports without a link to sleep mode. The D-Link DXS-1210-10TS 8-Port 10 Gigabit (10GbE) Smart Switch takes the approach to green IT one step further by incorporating a special chipset with advanced silicon technology for efficient use of energy.
Extensive Management and Layer 2 Features
Equipped with a complete lineup of L2 features, this D-Link DXS-1210-10TS includes port mirroring, Spanning Tree Protocol and Link Aggregation Control Protocol (LACP). Network maintenance features include loopback detection and cable diagnostics. Loopback detection is used to detect loops created by a specific port and automatically shut down the affected port. The cable diagnostic feature, designed primarily for administrators and customer service representatives, can rapidly discover errors and determine the cable quality, allowing the switch to manage itself for you.
QoS, Bandwidth Control
This D-Link DXS-1210-10TS 8-Port 10 Gigabit (10GbE) Smart Switch supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN is a new, industry-leading technology that this switch provides. This technology consolidates data and surveillance video transmission through a single unit thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data.
The Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and individual VLAN, these features guarantee the quality and security of VoIP traffic. Furthermore, the DSCP markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets. In addition, with bandwidth control, network administrators can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
Secure your Network
D-Link's innovative Safeguard Engine protects the switches against traffic flooding caused by malicious attacks. This D-Link DXS-1210-10TS 8-Port 10 Gigabit (10GbE) Smart Switch supports 802.1X port based and host based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network.
This DXS-1210-10TS includes ARP spoofing prevention, which protects from attacks on the network that may allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages. To prevent ARP spoofing attacks, the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP server screening feature rogue DHCP server packets from user ports to prevent unauthorised IP assignment.
Versatile Management
This D-Link DXS-1210-10TS 8-Port 10 Gigabit (10GbE) Smart Switch provides a D-Link Network Assistant Utility that simplifies the configuration for devices supporting D-Link Discovery Protocol. The D-Link network assistant utility easily allows customers to discover multiple D-Link Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC. It also simplifies the initial setup of the switches. Switches within the same L2 network segment that are connected to the user's PC are displayed on screen for instant access.
This allows extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. This D-Link DXS-1210-10TS also supports D-View 6.0 and Command Line Interface (CLI) through Telnet. D-View 6.0 is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
Seamless Integration
This D-Link DXS-1210-10TS comes with Ethernet copper ports capable of connecting to existing CAT5 twisted- pair cables, supporting CAT6 for 10GBASE-T. This DXS-1210-10TS has 8 10GBASE-T ports and 2 SFP+ ports. This means they provide a more flexible solution for upstream or downstream server connections, making network administration easy.
Standard Warranty: Limited Lifetime
Key Features
8x 10 Gigabit (10GbE) Ethernet RJ45 ports and 2x Combo SFP+ Ports
Power saving via: Link Status detection, LED Shut-Off, Port Shut-Off and System Hibernation
D-Link Network Assistant Utility or Web-based GUI
Built-in SNMP MIB for remote NMS (D-View 6.0)
Access Control List and IP-MAC-Port Binding
Clientless MAC/Web access control and D-Link Safeguard Engine
Auto Surveillance VLAN, Loopback Detection and Cable Diagnostics
Static Route, Auto Surveillance VLAN, LLDP/LLDP-MED and Auto Voice VLAN
  • Energy saving
    Incorporating D-Link green technology, the switch is capable of power-saving without sacrificing operational performance or functionality. The switches feature built-in smart fans, internal heat sensors monitor and detect temperature changes, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower, reducing the switch's power consumption and noise. Link status drastically reduces power consumption by automatically toggling ports without a link to sleep mode. The DXS-1210-10TS takes the approach to green IT one step further by incorporating a special chipset with advanced silicon technology for efficient use of energy.
  • Extensive management and Layer 2 features
    Equipped with a complete lineup of L2 features, the DXS-1210-10TS includes port mirroring, Spanning Tree Protocol and Link Aggregation Control Protocol (LACP). Network maintenance features include loopback detection and cable diagnostics. Loopback detection is used to detect loops created by a specific port and automatically shut down the affected port. The cable diagnostic feature, designed primarily for administrators and customer service representatives, can rapidly discover errors and determine the cable quality, allowing the switch to manage itself for you.
  • QoS, bandwidth control
    The DXS-1210-10TS supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN is a industry-leading technology that the DXS-1210-10TS 10 Gigabit Ethernet Smart Switch provides. This technology consolidates data and surveillance video transmission through a single unit thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. The Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and individual VLAN, these features guarantee the quality and security of VoIP traffic. Furthermore, the DSCP markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets. In addition, with bandwidth control, network administrators can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
  • Secure your network
    D-Link's innovative Safeguard Engine protects the switches against traffic flooding caused by malicious attacks. The DXS-1210-10TS supports 802.1x port based and host based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DXS-1210-10TS includes ARP spoofing prevention, which protects from attacks on the network that may allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages. To prevent ARP spoofing attacks, the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP server screening feature rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
  • Versatile management
    The DXS-1210-10TS provides a D-Link Network Assistant Utility that simplifies the configuration for devices supporting D-Link Discovery Protocol. The D-Link network assistant utility easily allows customers to discover multiple D-Link Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC. It also simplifies the initial setup of the switches. Switches within the same L2 network segment that are connected to the user's PC are displayed on screen for instant access. This allows extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The DXS-1210-10TS also supports D-View 6.0 and Command Line Interface (CLI) through Telnet. D-View 6.0 is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
  • Seamless integration
    The DXS-1210-10TS comes with Ethernet copper ports capable of connecting to existing CAT5 twisted-pair cables, supporting CAT6 for 10GBASE-T. The DXS-1210-10TS has 8 10GBASE-T ports and 2 SFP+ ports. This means they provide a more flexible solution for upstream or downstream server connections, making network administration easy.
D-Link DXS-1210-10TS - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
8 x 10GBase-T + 2 x 10 Gigabit SFP+
IGMP groups: 1000 , Virtual interfaces (VLANs): 4000 , ARP entries: 128 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , ACL rules: 512 , ACL: 512
MAC Address Table Size
16000 entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, SSH-2, CLI
Flow control, MDI/MDI-X switch, BOOTP support, ARP support, IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, DDos attack prevention, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), Safeguard Engine, D-Link Green Technology, LLDP support, DHCP relay, Port Security, SNMP trap, DHCP client, Dynamic VLAN Support (GVRP), Loopback, Type of Service (ToS), DiffServ Code Point (DSCP) support, Ethernet Ring Protection Switching (ERPS), IP source guard, Deficit Round Robin (DRR)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1ab (LLDP)
AC 120/230 V (50 - 60 Hz)
44 cm x 21 cm x 4.4 cm
3.1 kg
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
16000 entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Encryption Algorithm
SSL, TLS, SSL 3.0, SSL 2.0, PEAP, TTLS
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
Status Indicators
Port transmission speed, power, link/activity, fan
8 x 10GBase-T RJ-45 , 2 x SFP+
Internal power supply
68.67 Watt
VCCI, C-Tick, BSMI, cUL, CB, CCC, FCC, TLS
44 cm
21 cm
4.4 cm
3.1 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: Yes
POE: No
Brand: D-Link
Price Range Ex VAT: 500 - 750
