D-Link DWR-830 Mobile Wi-Fi/3G Router
Quicklinx: 9TSMWS00 Mfr#: DWR-830
D-Link's DWR-830 Mobile Wi-Fi Hotspot 42 Mbps uses your 3G DC-HSPA+ Internet connection to give you a simple and fast Wi-Fi network anywhere you need one. Instead of being confined to one Internet-connected device through a USB dongle, the DWR-830 allows you to create and share Wi-Fi hotspots anywhere you have a 3G signal. The compact size means you can conveniently take it with you and share your connection anywhere; use it in a cafe to send e-mails while your friend reads the news, or have your laptop, phone, and tablet all connected to the Internet at the same time using just one mobile Internet service.
  • Connect and share anywhere
    Simply insert your data-enabled USIM card, and this handy device will allow you to share a high speed 3G DC-HSPA+ mobile internet with download speeds of up to 42 Mbps. The DWR-830’s small size means you can easily slip it into your pocket or bag and take it with you wherever you go. For when you are on the road, the rechargeable 2380 mAh Li-on battery allows you to stay connected for longer between charges, and Universal Plug and Play (UPnP) means there’s no complicated software to install. Getting online with the DWR-830 Mobile Wi-Fi Hotspot 42 Mbps is quick, easy, and convenient.Security features to keep your network safeThe DWR-830 Mobile Wi-Fi Hotspot 42 Mbps is easy-to-use and includes a host of security features. The built-in firewall keeps connected computers and other devices safe from Internet intrusions, while WPA security encryption prevents unauthorized users from connecting to your network. Wi-Fi Protected Setup (WPS) helps you to create a secure wireless network, and add new devices with just the touch of a button, getting you securely connected in no time.
D-Link DWR-830 - mobile hotspot - 3G
Mobile hotspot
External
Max Transfer Rate
42 Mbps
Mobile Communication Protocol
GSM, GPRS, EDGE, DC-HSPA+
Mobile Band
GSM 850/900/1800/1900
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
2380 mAh
Apple MacOS, Linux, Microsoft Windows
10.03 cm x 4.935 cm x 1.413 cm
90 g
Mobile hotspot
External
Built-in Devices
Display
Modem
Wireless
Max Transfer Rate
42 Mbps
Mobile Band
Antenna
Internal
Antenna Qty
2
Wireless
Firewall protection, NAT support, Wi-Fi Protected Setup (WPS)
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
Supported Flash Memory Cards
microSD
1 x micro-USB - Type A
1 x USB cable
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Lithium Ion
2380 mAh
10.03 cm
4.935 cm
1.413 cm
90 g
-10 °C
55 °C
10 - 90% (non-condensing)
