D-Link's DWR-720 Mobile Wi-Fi Hotspot 21 Mbps uses your mobile 3G Internet connection to give you a simple and fast Wi-Fi network anywhere you need one. Get all your mobile devices connected to the Internet or share a 3G Internet connection with family, friends or colleagues when you are out and about.
- D-Link DWR-720 - mobile hotspot - 3G
- Mobile hotspot
- Form Factor
- External
- Max Transfer Rate
- 21.6 Mbps
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSDPA, HSUPA, AWS
- Mobile Band
- GSM 850/900/1800/1900 / UMTS 850/900/1900/2100
- Networking
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Battery
- 2000 mAh
- System Requirements
- Apple MacOS, Linux, Microsoft Windows
- 10.33 cm x 5.15 cm x 1.35 cm
- 77 g
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- OLED display
Modem
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 21.6 Mbps
- Mobile Band
- Antenna
- Internal
- Antenna Qty
- 3
- Wireless
- Data Link Protocol
- Firewall protection, NAT support, Wi-Fi Protected Setup (WPS), Samba support
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, UPnP
- Supported Flash Memory Cards
- microSD
- 1 x micro-USB - Type A
- Cables Included
- 1 x USB cable
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC
- Battery
- Lithium Ion
- Capacity
- 2000 mAh
- OS Required
- 10.33 cm
- 5.15 cm
- 1.35 cm
- 77 g
- -10 °C
- 55 °C
- 10 - 90% (non-condensing)
