Product
D-Link DWR-720 Mobile Hotspot 3G 21.6 Mbps 802.11n
Quicklinx: CQH3WS00 Mfr#: DWR-720
D-Link's DWR-720 Mobile Wi-Fi Hotspot 21 Mbps uses your mobile 3G Internet connection to give you a simple and fast Wi-Fi network anywhere you need one. Get all your mobile devices connected to the Internet or share a 3G Internet connection with family, friends or colleagues when you are out and about.
D-Link DWR-720 - mobile hotspot - 3G
Mobile hotspot
External
Max Transfer Rate
21.6 Mbps
Cellular Protocol
GSM, GPRS, UMTS, EDGE, HSDPA, HSUPA, AWS
Mobile Band
GSM 850/900/1800/1900 / UMTS 850/900/1900/2100
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
2000 mAh
Apple MacOS, Linux, Microsoft Windows
10.33 cm x 5.15 cm x 1.35 cm
77 g
Mobile hotspot
External
Built-in Devices
OLED display
Modem
Wireless
Max Transfer Rate
21.6 Mbps
Mobile Band
Cellular Protocol
Antenna
Internal
Antenna Qty
3
Wireless
Firewall protection, NAT support, Wi-Fi Protected Setup (WPS), Samba support
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, UPnP
Supported Flash Memory Cards
microSD
1 x micro-USB - Type A
1 x USB cable
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Lithium Ion
2000 mAh
10.33 cm
5.15 cm
1.35 cm
77 g
-10 °C
55 °C
10 - 90% (non-condensing)
