The DWA-582 Wireless AC1200 Dual-Band PCI Express Adapter connects your computer to a high-speed network and provides a blazing-fast Wireless AC connection with superior reception. Once connected, you can access your network's high-speed Internet connection while also getting secure access to shared photos, files, music, video, printers and storage.
Upgrade to wireless AC performance
By upgrading your laptop and desktop computers to AC, you can immediately enjoy the benefits of faster wireless speeds and better connectivity - all with less wireless interference so you can enjoy doing what you love most. Delivering Wi-Fi dual band speeds to your laptop or desktop computer, the DWA-182 is the perfect solution for those looking to enjoy online gaming, smooth HD video streaming, fast file transfers and lag-free video chatting. -
Backward compatibility
While the Wireless AC1200 Dual Band USB Adapter delivers blazing fast AC speed to your laptop or desktop computer, it's also backward compatible with older Wi-Fi routers and devices - no updates or adapters necessary. -
Easy push button setup
Quickly and easily establish a fast, secure home network that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
- D-Link Wireless AC1200 DWA-582 - network adapter
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Bus Voltage
- 3.3 V
- 2.5 cm x 12.1 cm x 7.9 cm
- 48.8 g
- Data Link Protocol
- 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
- Network adapter
- Form Factor
- PCI Express x1
- Bus Voltage
- 3.3 V
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 4.5 dBi
- Included Accessories
- Low-profile bracket
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- C-Tick, IC, FCC, NCC
- Software Included
- Drivers & Utilities
- 2.5 cm
- 12.1 cm
- 7.9 cm
- 48.8 g
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
