D-Link DWA-192 AC1900 Wi-Fi USB 3.0 Adapter
Quicklinx: B984WS00 Mfr#: DWA-192
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11a, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
£49.90 ex VAT
£59.88 inc VAT
The AC1900 Ultra Wi-Fi USB Adapter lets you upgrade your desktop or laptop to the latest generation wireless AC speeds, so you can easily stream HD media, download music, and enjoy high-speed online gaming.
  • AC1900 Ultra Wi-Fi USB Adapter
  • More speeds for PCs and Macs
    The DWA-192 is powered with a 3 x 3 antenna design supporting speeds of up to 600 Mbps on the 2.4 GHz and 1300 Mbps on the 5 GHz to deliver fast wireless speeds and less interference for maximum throughput. It is the perfect match for your high performance router.
  • Do more with Dual-Band
    Use the 2.4 GHz Band for everyday takes such as surfing the web or chatting online while leaving the high-speed 5GHz AC Band free for video streaming, online gaming and large file transfers.
  • Advanced AC SmartBeam technology
    Improves coverage by directing bandwidth to your devices as you move around your home. You can stream HD video, surf the web, skype your friends and play online games from wherever you are so you will always get the best experience.
  • High powered amplifiers
    Want some wall penetrating Wi-Fi performance with three times the range of standard Wi-Fi adapters? The DWA-192 will extend the signal to your router.
  • USB 3.0
    SuperSpeed transfer mode will let you transfer data 10x faster than USB 2.0 standard. Get increased performance and better power management.
  • Made for larger homes
    Have a home with lots of devices and rooms? Using the latest AC technology, this adapter will give you better wireless coverage and better speeds so that you are connected in more places.
  • Unique design
    With its cool looking design, the DWA-192 is the only AC1900 USB adapter that comes with a design that will get everyone's attention.
  • Works with all routers
    Worried about the DWA-192 not working with your older router and range extender? The DWA-192 is compatible with all brands of Wi-Fi routers and range extenders.
D-Link DWA-192 - network adapter - USB 3.0
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
7.992 cm x 7.992 cm x 7.7 cm
167 g
802.11ac
Data Transfer Rate
1300 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Microsoft Windows 7 / 8 / 8.1
Network adapter
External
SuperSpeed USB 3.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
1300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Wi-Fi Protected Setup (WPS), on/off switches
Aerial
Antenna
Internal
Encryption Algorithm
WPA, WPA2
RoHS, RCM
7.992 cm
7.992 cm
7.7 cm
167 g
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: D-Link
