D-Link Dual Port 10GBASE-T RJ45 PCI Express Adapter
Quicklinx: D0XDWS00 Mfr#: DXE-820T
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Compatibility: PC
Type: Network adapter
£247.34 ex VAT
£296.80 inc VAT
Add 10 Gigabit connectivity to your server or high-powered workstation with the D-Link DXE-820T Dual Port 10 Gigabit Ethernet PCIe Adapter. It is a high performance network adapter which combines 10GBase-T with high-speed PCI Express 2.0 x8 interface.
  • Advanced features and security
    The card features onboard screening of 802.1Q VLAN tagged Ethernet frames, allowing you to assign multiple subnets to each server and isolate devices within each VLAN from the rest of the network for better traffic control and security. With support for advanced features such as 802.3x Flow Control, Jumbo Frames, and SNMP for network management, the DXE-820T can easily interoperate with your current networking equipment.
  • Performance and reliability
    The DXE-820T increases network throughout by utilizing PCI Express bus architecture. With Smart Load Balancing the DXE-820T configures multiple adapters to work as a team, sharing traffic and ensuring data reliability. This both creates a faster network and provides fault tolerance resulting in a stable and efficient network.
  • Checksum offloading
    The DXE-820T features TCP, UDP, and IP checksum offloading functionality, which transfers the checksum processing tasks from the computer's CPU to the network card. The DXE-820T's ability to handle the checksum processing means that the CPU's processing power can be used for other tasks while still achieving 20 Gbps network speeds.
D-Link DXE-820T - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8 / PCI Express x16
Bus Voltage
3.3 V
Ports
10Gb Ethernet x 2
12.09 cm x 18.1 cm x 2.16 cm
Cabling Type
Ethernet 10GBase-T
10 GigE
Data Transfer Rate
10 Gbps
IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3an, IEEE 802.3az
Microsoft Windows Server 2008 x86 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2008 R2 (64-bits), Oracle Solaris 11 11/11, Microsoft Windows Server 2008 (64-bits)
D-Link Data Center 10GbE Top-of-Rack Switch DXS-3600; DXS 1100-16SC, 1210-16TC, 3400-24SC, 3400-24TC, 3600-16S
Network adapter
Plug-in card
Bus Voltage
3.3 V
Ports
10Gb Ethernet x 2
Wired
Cabling Type
Ethernet 10GBase-T
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Port transmission speed, active, link/activity
Flow control, Quality of Service (QoS), Jumbo Frames support, Receive Side Scaling (RSS), NIC Partitioning (NPAR), Energy Efficient Ethernet, 96KB packet buffer, adaptive routing, Class of Service (CoS), Smart Load Balancing (SLB)
1 x 10GBase-T - RJ-45
C-Tick, FCC
12.09 cm
18.1 cm
2.16 cm
10 - 90% (non-condensing)
D-Link Data Center 10GbE Top-of-Rack Switch DXS-3600 , D-Link DXS 1100-16SC, 1210-16TC, 3400-24SC, 3400-24TC, 3600-16S
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 150 - 300
