The DNS-327L ShareCenter + 2-Bay Cloud Network Storage Enclosure is an easy-to-use yet powerful and versatile solution for accessing, sharing, and backing up your important data by creating your own personal cloud. Keep all of your data safely stored and protected at home, and still have it at your fingertips wherever you are.
A complete home storage solution
D-Link ShareCenter 2-Bay NAS (DNS-327L) is the perfect home solution to share, stream, manage and back up all of your digital files by creating your own personal Cloud. Remotely connecting to your ShareCenter is as easy as downloading the free mydlink Access mobile app. The NAS mobile app, allows you to access your files and stream music, video and photo content to your smartphone or tablet from anywhere around the world. Plus, the simple and intuitive hardware design lets you easily add up to two 3.5" SATA hard drives to your device without the use of any tools, making the ShareCenter a powerful, scalable solution for your home or office. -
mydlink easy remote manager
Experience the full benefits of managing your files using mydlink remote manager. conveniently access your NAS applications - My Music, My Files, My Photos, P2P downloads via mydlink from anywhere. You can manage your P2P downloads, view your photos, stream music, and enjoy the versatile remote accessibility ShareCenter delivers.
- D-Link ShareCenter + 2-Bay Cloud Network Storage Enclosure DNS-327L - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 9 cm x 14.43 cm x 19.53 cm
- 0.64 kg ()
- Storage Controller
- 1 x RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, 1GbE
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 9 cm
- 14.43 cm
- 19.53 cm
- 0.64 kg ()
Storage Controller
- 1 x RAID
- Interface Type
- SATA 3Gb/s
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- TCP/IP, NTP, DHCP
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Apple Bonjour Protocol, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Web server, torrent/P2P data exchange, D-Link Green Technology, Apple Time Machine compatible
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0, DLNA CERTIFIED, UPnP
- Expansion Bays
- 2 (total) / 2 (free) x hot-swap - 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A
- IC, FCC
- Power Device
- External power adapter
- 28.8 Watt
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
