Introducing the first member of the new Ultra Performance Series of networking devices, the Wireless AC3200 Tri-Band Gigabit Router (DIR-890L).
Equipped with the most advanced features and optimized for maximum speed, coverage and performance, the Wireless AC3200 Tri-Band Gigabit Router (DIR-890L) gives you ultra-enhanced network performance ideal for large homes and demanding users. Now you can experience uncompromised HD streaming and gaming on each and every connected device in and around your home.
Advanced Features that will make you FEEL THE DIFFERENCE
Enhanced quality of service (QoS), ultra fast connectivity and DLNA support combine to provide a buffer-free 4K HD video streaming experience.
Dual core processor, Gigabit ports, and advanced QoS combine to deliver lagfree gaming.
Advanced QoS prioritizes the most important data so you get lag-free gaming and uninterrupted streaming on multiple devices.
Designed to get maximum performance from the growing number of connected devices in the home.
Gigabit Ports provide all of your wired devices with blazing fast 10/100/1000 Mbps connections.
Dual USB Ports (USB3.0 & USB2.0) let you locally and remotely stream content from up to two connected USB drives using the free mydlink SharePort app.
Advanced wireless security with WPA2 and enhanced network security with dual active NAT and SPI firewalls.
Free mydlink Lite mobile app for monitoring and controlling your network.
Backward compatible and optimized to get the best performance out of both legacy and newer Wi-Fi devices.
- Next Generation 11AC Wi-Fi - Newest AC technology for ultra high-speed wireless connections
- Simultaneous Tri-Band - Delivers faster Wi-Fi speeds of up to 3200Mbps (600Mbps on 2.4Ghz + 1300Mbps + 1300Mbps on 5GHz)
- Ultra Range - Powerful amplifier, 6 high-gain antennas and Advanced AC SmartBeam technology combine for enhanced Wi-Fi speed and coverage *
- SmartConnect - Increases bandwidth efficiency and availability
- Dual Core Processor - Gives you increased performance to support more devices and provide faster throughput
- Gigabit Ethernet - Delivers wired performance 10x faster than traditional Fast Ethernet
- Your Own Personal Cloud Storage - mydlink SharePort enabled USB port so you can store and access your media files wherever you are
- USB 3.0 - Up to 10x faster than USB 2.0
- Compatibility - Works with existing and future Wi-Fi devices
Super-charged with smarter wireless AC features
The D-Link DIR-890L Wireless AC3200 Tri Band Gigabit Cloud Router creates a blazing fast home network that connects all of your computers and mobile devices to your broadband Internet connection. The SmartConnect technology ensures that older wireless devices do not degrade the overall performance of the DIR-890L and allows wireless AC devices to have a total throughput of 3200 Mbps. The SmartConnect technology is designed to integrate all of the DIR-890L radio interfaces into one Wi-Fi network name, which provides users with one simple, easy-to-use wireless connection that will provide them with the bandwidth and reliability that only D-Link products can give. -
File sharing at your fingertips
The mydlink SharePort app allows you to connect a USB storage device to the DIR-890L and instantly share documents, movies, pictures, and music with mobile devices. Put your music library on a USB drive and share it with everyone else in your home, or show photos on the living room TV while a family member watches a movie on their mobile device. Stream media files to multiple devices without interruption, or save them to your device for offline playback. The intuitive interface lets anyone immediately connect to a variety of entertainment options stored securely on your own storage device. -
Reliable and efficient
Using the Wireless AC technology, which can provide transfer rates of up to 3.2 Gbps, the DIR-890L operates on both the 2.4 GHz and two 5 GHz wireless bands at the same time using concurrent tri-band technology and six external antennas. This allows you to browse the web, chat, and email using the 2.4 GHz band, while simultaneously streaming digital media, playing online games, or making Internet phone calls on the 5 GHz band. Advanced Quality of Service (QoS) prioritizes the most important data, such as movie streaming and online gaming; its SmartConnect feature efficiently balances the data load between the three bands, while airtime fairness ensures that wireless clients are provided with the most appropriate bandwidth for their needs. -
Easy to set up and use
Get the DIR-890L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile App on your smartphone or tablet. Simply plug in the router, open the App, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi protected setup. Simply press the WPS button to instantly establish a secure connection to a device. If you have additional mydlink cloud products, you can take advantage of mydlink Zero Configuration. Simply connect your mydlink-enabled device to the DIR-890L and the router will automatically link it to your mydlink account with no configuration required. -
Use mydlink to monitor your network
The Wireless AC3200 Tri Band Gigabit Cloud Router is mydlink cloud enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from an Internet connected PC, tablet, or smartphone. Parents can monitor what sites their children are visiting, to stay informed and in control on the go.
- D-Link DIR-890L - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 3200 Mbps
- PPTP, L2TP, IPSec
- Remote Management Protocol
- HTTP
- Firewall protection, NAT support, SPI, IPv6 support, VPN passthrough, Zero Configuration Technology, WMM support, QoS, WPS, Green Ethernet, reset button, DLNA Media Server, SharePort Technology, VPN Server, Guest Zone support, Advanced AC SmartBeam technology, SmartConnect Technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 37.3 cm x 24.1 cm x 15.7 cm
- System Requirements
- Apple MacOS X 10.4 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 3200 Mbps
- PPTP, L2TP, IPSec
- HTTP
- Encryption Algorithm
- WPA, WPA2
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac, IC, FCC
- Status Indicators
- Power, WLAN, USB, WPS, Internet
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External integrated
- Antenna Qty
- 6
- Power Device
- External power adapter
- Voltage Required
- OS Required
- 37.3 cm
- 24.1 cm
- 15.7 cm
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
