The DIR-879 AC1900 Wi-Fi Router brings a host of new technologies to create the best wireless networking experience to date. Gigabit wireless connectivity of up to 1900 Mbps (up to 1300 Mbps 5 GHz Wireless AC + up to 600 Mbps 2.4 GHz Wireless N2) allowing you to create a blazing fast home network that connects all of your computers, game consoles, 3D/4K video capable set top boxes, smart TVs and mobile devices to your broadband Internet connection. Plus, with AC SmartBeam technology you don't have to worry about your existing devices limiting performance.
Extreme Wi-Fi coverage
With its built-in high power amplifier and antenna diversity you can enjoy wider wireless coverage throughout your home. -
Smart beam forming
Improves coverage by directing bandwidth to your devices as you move around your home. You can stream HD video, surf the web, call your friends and play online games from wherever you are so you'll always get optimal experience. -
Smart connect
Not all Wi-Fi bands are the same, but you don't need to worry about that. With Smart Connect technology, the DIR-879 chooses from the two Wi-Fi bands and automatically connects each device on your network to the optimal band available for excellent connection. -
Intelligent QoS
Intelligent QoS tracks the type of network traffic (media streaming, web surfing, online gaming) and decides which application deserves higher priority. -
Easy user interface
Controlling your network by enabling parental controls, blocking unwanted devices, monitoring Internet activity and creating Wi-Fi guest networks is easier than ever with the user friendly interface.
- D-Link DIR-879 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1900 Mbps
- NAT support, Stateful Packet Inspection (SPI), IPv6 support, VPN passthrough, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green Ethernet, DLNA Media Server, SmartBeam technology, Guest Zone support, SmartConnect Technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 20.1 cm x 24.1 cm x 8.9 cm
- System Requirements
- Microsoft Windows 7, Apple MacOS X 10.7 or later, Windows 8 / 8.1, Windows 10
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1900 Mbps
- Encryption Algorithm
- WPA, WPA2
- Processor
- 1 x 1 GHz
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable
- OS Required
- 20.1 cm
- 24.1 cm
- 8.9 cm
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
