Product
D-Link DIR-868L Wireless AC1750 Dual-Band Gigabit Cloud Router
Quicklinx: 8VLJWS00 Mfr#: DIR-868L/E
  • IEEE 802.11n
The DIR-868L Wireless AC1750 Dual-Band Gigabit Cloud Router lets you easily connect to, control and monitor your network using the future of wireless technology and unique mydlink. By downloading the free mydlink app you can monitor your home network remotely. Plus, with the included SharePort Technology, accessing and sharing your files, playlists and videos have never been so easy.
This router creates the fastest home network possible today connecting all of your computers and mobile devices to your broadband Internet connection. Concurrent dual-band 802.11ac with D-Link's AC SmartBeam technology brings you the future of high-bandwidth wireless connectivity, allowing you to stream HD video, make Internet calls, and surf the Internet from every corner of your home without interruption. Gigabit Ethernet ports provide high-speed wired connections for up to four PCs or other devices. It's stylish, easy-to-use, and is IPv6-ready for a reliable network today and tomorrow.
The DIR-868L uses the latest Wireless AC technology, which can provide transfer rates of up to 1.3 Gbps. D-Link's intelligent AC SmartBeam technology guarantees continuous blazing fast wireless speeds to all your devices, anywhere in your home, even under heavy network utilization or in rooms that have bad wireless signal. Faster gigabit wireless speeds allow you to download contents and sync files over 4 times faster than the previous standard and provide you with whole home coverage. The router operates on both the 2.4 GHz band and 5 GHz wireless bands at the same time using concurrent dual-band technology and six internal antennas. This allows you to browse the web, chat and e-mail using the 2.4 GHz band, while simultaneously streaming digital media, playing online games, or making Internet phone calls on the 5 GHz band.
This router gives you complete control by allowing you to monitor who is connecting to your network, which sites they are visiting and block unwanted visitors. You can monitor your home network remotely through the mydlink web portal or by downloading the free mydlink app available for your iOS or Android devices.
Connect a USB storage device to your DIR-868L to create a shared storage space, making it easy to access and share files between computers and devices connected to your network. Plug in a USB hard drive to stream your library of videos and music to your laptop. Plus, the SharePort Mobile app for iOS and Android devices allows you to back up photos and videos stored on your device. You can even customize your shared storage space by creating separate accounts to control access to the USB drive, so you can share your music with everyone but keep your personal files private. This Cloud Router can also be used as a media server for your home to stream media stored on your USB storage drive to any DLNA compliant player like the Boxee Box by D-Link.
Get the DIR-868L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your iOS or Android device. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup. Simply press the WPS button to instantly establish a secure connection to a new device. If you have additional mydlink products, you can take advantage of mydlink Zero Configuration. Simply connect your mydlink-enabled device to the DIR-868L and the router will automatically link it to your mydlink account with no configuration required.
  • Wireless AC - fast Wi-Fi
    What does Wireless AC mean for your home network? Flawless HD video streaming, faster gaming, and lag-free Skype and Facetime calls, all with less Wi-Fi interference for smooth, lightning-fast performance. And while your home gains all the cutting-edge benefits of AC, the Wireless AC1750 Dual Band Gigabit Cloud Router is also compatible with all of your current Wireless N products. And with 4 Gigabit ports, you can give your media players and gaming consoles more speed than you dreamed possible.
  • Dual Band technology
    The Wireless AC1750 Dual Band Gigabit Cloud Router delivers Dual Band Technology for intelligent, versatile, interference-free bandwidth. Check your email and surf the Internet on the 2.4 GHz band; or game, make Skype calls and stream HD movies to multiple devices using the cleaner, interference-free band. Whatever you like to do online, Dual Band has you covered.
  • Enhanced coverage
    With its built-in high-powered amplifier, you can enjoy wireless coverage throughout your home with the Wireless AC1750 Dual Band Gigabit Cloud Router. Watch videos in an upstairs room, Skype from your home office, or browse and stream from your couch - with the Wireless AC1750 Dual Band Gigabit Cloud Router you can connect wherever and however you want.
  • Local file access through SharePort Mobile
    With the free SharePort Mobile app and built-in USB port, you can locally access your favorite videos, music and photos on a connected USB device wirelessly from your tablet or Smartphone. Supporting storage devices of up to 500 GB, the SharePort Mobile app lets you quickly and easily store thousands of movies, pictures, movies and more, all in one centralized location. The friendly interface lets you easily find your files by category, whether you're looking for music, video or documents. And with DLNA, the Wireless AC1750 Dual Band Gigabit Cloud Router not only connects to any Ethernet-equipped device, but virtually any device, automatically.
D-Link DIR-868L - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz / 5 GHz
NAT support, Stateful Packet Inspection (SPI), IPv6 support, VPN passthrough, parental control, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), SharePort Plus Technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac (draft 2.0)
12.33 cm x 10.23 cm x 21.7 cm
0.56 kg
Microsoft Windows XP SP2, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Windows 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac (draft 2.0), C-Tick, IC, FCC
Status Indicators
Power, WAN, WPS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable
12.33 cm
10.23 cm
21.7 cm
0.56 kg
10 - 95% (non-condensing)
Network Adaptors (1)
Expand your network
8VLJ C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
Other bundles (6)
8VLJ C2G 2m USB 2.0 A/B Cable - Black In Stock £3.87
8VLJ C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
8VLJ C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
8VLJ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
8VLJ C2G USB Superbooster Extender Kit In Stock £37.81
8VLJ C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
