The Connect and share an Internet connection, or charge your mobile devices anytime, anywhere, with D-Link's DIR-510L Wi-Fi AC750 Portable Router and Charger. Share files, stream media, and browse the Internet with the superb speed and performance provided by the latest Wireless AC technology. Simply connect your laptop, smartphone, or tablet to the DIR-510L's wireless network and it will take care of the rest. With the built-in high-capacity rechargeable battery, this portable charger gives power to your mobile device so that you can talk, listen to music, watch videos or surf the web for longer.
Wireless AC for breakthrough performance
The DIR-510L incorporates the latest Wireless AC750 technology for unprecedented range and data transfer performance to and from compatible Wi-Fi devices. By using dual bands to bypass radio congestion and interference, the router can deliver a total of 750 Mbps using the combined bandwidth of its 2.4 GHz and 5 GHz bands. Moreover, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs. You can even configure a guest zone to give visitors Internet access without giving them access to the rest of your network. Combined with support for Universal Plug and Play (uPnP) and a built-in DLNA server, you can stream your multimedia collection smoothly and securely across all your devices and appliances, including smart TVs, game consoles, and media PCs. -
Your mobile power station
The DIR-510L's built-in high-capacity 4000 mAh rechargeable battery not only powers the device itself, it also keeps your gadgets charged and ready to go. The device provides two USB ports so you can charge a device and share files from a USB drive at the same time. You no longer have to worry about your smartphone's battery running out of juice while on-the-move. Simply connect your smartphone or high-power devices like iPads to the USB port to start charging anywhere, anytime. -
Easy to set up, easy to use
The DIR-510L includes a user-friendly interface that stores your connection details for you so you only have to enter them once. Whether you're connected via your 3G/4G adapter for mobile Internet or to the Wi-Fi hotspot of your favorite café, the DIR-510L helps you keep all of your devices connected, automatically
- D-Link DIR-510L - wireless router - Wi-Fi 5 - desktop
- Wireless router
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 750 Mbps
- NAT support, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, SharePort Technology, USB charger, built-in rechargeable battery
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, USB 2.0, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft)
- 5.9 cm x 1.6 cm x 14 cm
- 154 g
- Wireless router
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 750 Mbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, USB 2.0, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft), C-Tick, BSMI, cUL, IC, FCC, LVD, NCC
- Status Indicators
- Power, status, battery
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- 5.9 cm
- 1.6 cm
- 14 cm
- 154 g
- 0 °C
- 40 °C
- 10 - 75% (non-condensing)
